Ipad 2 display lines
This is a discussion on Ipad 2 display lines within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Display was fine and then turned it on & now it's not is it the display itself or connection issue. Thanks...
Results 1 to 6 of 6
    256955
    Nov 2012
    Hawaii
    Exclamation Ipad display lines
    Ipad 2 display lines-ipad2.jpg Display was fine and then turned it on & now it's not is it the display itself or connection issue.
    256335
    Nov 2012
    25
    looks like its broken perfectly down the middle...
    maybe the gpu is actually 2 gpu's and one is dead...
    id take it to the apple store and show them :|
    256955
    Nov 2012
    Hawaii
    Thanks for the help.
    Moderator
    235421
    122 times
    Aug 2012
    Adelaide, South Australia
    1,912
    Quote Originally Posted by Chababe62 View Post
    Attachment 28938 Display was fine and then turned it on & now it's not is it the display itself or connection issue.
    Whenever your iPad acts a bit weird, rather than listening to any doomsayers suggesting there is something wrong with it and should be immediately taken back to Apple, first try to do a Full Reset of your machine. (Sorry if you already know about this)
    Here's how: hold down your Home and Power On/Off buttons at the same time until the screen goes dark. Keep holding both down until the Apple logo appears, then let both go. Then wait, could be a while, until the On slide button appears. You have reset your iPad, and not lost any info whatever but tidied up its internals.
    Let us know how that went, good or not good. Unless there is something really physically wrong with your iPad, there are solutions via these forums that could help you.
    Regards, Andrew🐨
    ​Please come back to say whether a member's assistance solved a problem. Others may be helped by that.
    Everybody please read the forum rules--->
    iPad3 64gig black, PC Windows 8 Pro, Samsung Galaxy mobile phone, Electrolux refrigerator (cool version)
    256955
    Nov 2012
    Hawaii
    Thanks Andrew , no hard rest didn't work also when i turn the ipad the lines stay and digitizer
    seems to work.
    Moderator
    235421
    122 times
    Aug 2012
    1,912
    seems to work.
    OK, a couple more things you could do before finally deciding to take your iPad back to Apple, the last more drastic than the first:
    (A). Settings, General, Reset and then tap "Reset all Settings" this resets all your preferences and settings but you still retain data such as contacts, calendars and media such as songs and videos.
    (B). Erase all content and settings and bring your iPad back to "factory fresh" status, as follows:
    Settings, General, Reset and then tap "Erase all Content and Settings". You will lose all your data and settings but will start off
    again at the point where you acquired you iPad.
    Now if those lines stay it could be your poor iPad physically😰 Love to know how you got on
    All the best, Andrew🐨
  1. Three Horizontal Lines in Display
    By sermarco in forum iPad 2 Forum
    Last Post: 06-11-2012, 06:43 AM
  2. ipad screen red and blue lines
    By Cotters007 in forum iPad General Discussions
    Last Post: 01-19-2012, 05:50 AM
  3. Replies: 0
    Last Post: 05-13-2011, 12:15 PM
  4. Replies: 0
    Last Post: 03-16-2011, 06:41 PM
  5. iPad 3G Lines
    Last Post: 05-01-2010, 10:09 PM
digitizer replacement
display lines
ipad 2 display post lines
ipad display lines
ipad lines in display
ipad lines on display
lines ipad 2 display
