default login
This is a discussion on default login within the iPad 2 Forum forums, part of the Apple iPad Discussions category; ok I am using an ipad I got from my mom who passed away before ever getting to use it. She did get apple to ...
Results 1 to 2 of 2
Thread: default login
    131208
    2 times
    Dec 2011
    48
    default login
    ok I am using an ipad I got from my mom who passed away before ever getting to use it. She did get apple to set it up I ned to change all the logins to mine for some reason somethings still open under her id is there a place where I can change the main apple id and password or should or just do a reset??
    David E
    shssssssssssh dont tell anyone I have a GIII
    And SPECIAL thanks to all the staff and mods who have the never ending almost thankless job
    579 times
    Dayton, WA
    13,187
    Sorry to hear about your Mother.
    You are better off just restoring it. Anything purchased under her Apple ID (doesn't sound like it would be much) will need updating eventually anyway, and you can't do that without the ID.
    If it is version iOS 5 or newer you can do it under Settings > General > Reset > Erase all Content and Settings. It will go through a setup where you can enter your Apple ID and other pertinent information. You need to have a wi-fi network available.
    If it's iOS 4 or older you'll need to connect it to a computer running the latest version of iTunes. It will want to update to the newest iOS, and unless you have a good reason not to (like you really want to jailbreak) you might as well let it. Be prepared for it to take a while. You can do it this way with the newer iOS version as well.
    To tell what iOS version you are running check under Settings > General > About > Version.
    Good luck.
  1. Login and passwords
    By tommg3999 in forum iPad General Discussions
    Last Post: 09-28-2012, 12:17 PM
  2. Youtube app can't login
    By traildad in forum iPad Help
    Last Post: 03-31-2012, 11:17 PM
  3. TD Ameritrade App - Can't login !
    By Windsors in forum iPad Apps
    Last Post: 02-11-2012, 08:35 AM
  4. Can't login using IPF
    By Pszilard in forum iPad Apps
    Last Post: 05-27-2011, 01:29 AM
  5. Can't login using IPF
    By Pszilard in forum New Member Introductions - Site Assistance
    Last Post: 05-26-2011, 01:41 PM
