Results 1 to 6 of 6
    256073
    Nov 2012
    United Kingdom
    5
    Ipad Newbie help
    I have just bought an Ipad2 and would like to put some of my Pictures and Videos onto it to view. I beileve you have to do this through Itunes, is that correct...I did try it using Itunes, and either dragging the pics into Itunes or even direct to the Ipad shown in Itunes, it didnt work....If there is a method of doing this without going through Itunes it would be great. Also why doesnt my Ipad show up on the MY COMPUTER function on my PC ?
    Thanks for any help
    Moderator
    131244
    732 times
    Dec 2011
    Regina,Canada
    15,112
    Your iPad is supposed to show Up in iTunes on your computer, not in the my computer section.
    256073
    Nov 2012
    United Kingdom
    5
    Ipad shows up in Itunes no problem and I have managed to transfer Photos from my Itunes library to the Ipad....However when I try to transfer an MP4 video from my Itunes library to the Ipad, an error message appears and says cannot transfer as Ipad cannot play this video......anyone got any ideas why not ?
    172313
    Mar 2012
    Central Ohio
    85
    No guarantees but you might want to make sure your MP4 files meet these criteria, specifially the H.264 video codec.
    Playing MP4 on iPad 3 is usually smooth for many users. However, due to codec, video size and resolution issue, you may have difficulty in adding MP4 to iTunes and transferring MP4 to iPad 3. Sometimes, even though you can transfer MP4 to iPad 3, the MP4 file just cannot be played on iPad 3.
    In order to successfully play MP4 files on the iPad 3, MP4 files shall meet the following requirements:
    • H.264 video up to 720p, 30 frames per second, Main Profile level 3.1 with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio;
    • MPEG-4 video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Simple Profile with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio.
    Your iPad will not recognize the MP4 files if they don’t match the above requirements.
    256073
    Nov 2012
    United Kingdom
    5
    its the H.264 that soryted it THANKS for your help....However there is a small problem, the thumbnails appear as though they are a negative image on the video screen of the Ipad, do you have any idea why or what I have done, otherwise the video clips play fine.....Once again THANK YOU!!!
    Banned
    129445
    3 times
    Nov 2011
    United States
    255
    You just might need a video converter even though you might think your mp4 files are correct some times they need fixing to work on the iPads. I use Miro video converter it's free and works great. Miro Video Converter FREE - Convert any video to MP4, WebM (vp8), iPhone, Android, iPod, iPad, and more.
  1. iPad 3 4G Newbie
    By cyberdroxxx in forum New Member Introductions - Site Assistance
    Last Post: 06-24-2012, 10:37 PM
  2. Hello from an iPad newbie
    By Plan B in forum New Member Introductions - Site Assistance
    Last Post: 03-28-2012, 08:10 AM
  3. Newbie to iPad
    By Alstuff in forum New Member Introductions - Site Assistance
    Last Post: 09-25-2011, 07:24 AM
  4. newbie to ipad
    By shellyskitty in forum New Member Introductions - Site Assistance
    Last Post: 04-29-2011, 02:17 AM
  5. Ipad newbie...newbie problems
    By piper109 in forum New Member Introductions - Site Assistance
    Last Post: 12-19-2010, 10:58 AM
