How to move a file audio from ipad to my pc
This is a discussion on How to move a file audio from ipad to my pc within the iPad 2 Forum forums, part of the Apple iPad Discussions category; If you got those books from the Apple bookstore, you can delete them from the iPad. They will still be available for a free download ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
  1. #11
    13576
    1457 times
    Aug 2010
    Western NY state (USA)
    11,073
    If you got those books from the Apple bookstore, you can delete them from the iPad. They will still be available for a free download any time you wish to read the book.
    If they are books from other places, then, depending on which app you use to read them with, yes, you can do cloud storage. Something like Dropbox would work.
  3. #12
    98056
    Sep 2011
    51
    So if i am correct i must download dropbox on my imac and then move my books from ipad to imac, correct?
  4. #13
    13576
    1457 times
    Aug 2010
    11,073
    Which app are you using to view those books on your iPad? Knowing that can help us figure out how to get them to Dropbox.
  5. #14
    98056
    Sep 2011
    51
    Frankly speaking I don't know.
    There are books and magazines in pdf format and i can open and read them without problems
  6. #15
    98056
    Sep 2011
    51
    I mean they open automatically after being in ibooks app
  7. #16
    98056
    Sep 2011
    51
    They are all in ibooks
  8. #17
    1546 times
    Walla Walla, WA
    15,468
    If you want to keep PDF books in a cloud service and only download them when needed you'll have to use a different app than iBooks.
    Both GoodReader and PDF Expert have DropBox integration built in. Once you set them up you can upload/download files directly to DropBox.
    You could also use the free Adobe Reader app along side the DropBox app. You would use the DropBox app to download and then use Open In to copy it to Adobe Reader.
    There are lots of other PDF readers out there.
    Basically, you download the books from DropBox to the reader of choice, read them, then delete them when you were done.
    iBooks does not have DropBox support, though you could use it like Adobe Reader by downloading in the DropBox app then Open In the iBooks app; delete when done.
    While there is no way to copy/sync a PDF directly from iBooks on the iPad to the computer, you can email it to yourself. This is the only way to get a PDF out of iBooks. They can not be synced back to iTunes. Only books purchased in the iBooks store will transfer from the iPad back to iTunes on a computer.
    Personally, I do none of these.
    Instead I add all my PDF books to iTunes on the computer first, then I sync them back to the iPad. That way I have a copy on the computer, and I can add or delete them from the iPad by changing my sync settings and re-syncing. Unlike syncing form the iPad to the computer, this direction works fine.
    However, some people don't like to use iTunes. In that case the earlier suggestions should work fine.
  9. #18
    98056
    Sep 2011
    51
    Well this is a complete and exhaustive reply
    Thanks a lot twerppoet
  1. Move File From iBooks to Goodreader
    By jeff911 in forum iPad 1 Forum
    Last Post: 10-07-2012, 11:38 AM
  2. How do you inset audio file in slide in keynote?
    By paul.rene in forum iPad at Work
    Last Post: 03-24-2012, 09:09 AM
  3. How can I view folder and file structure and move files
    By Marnhullman in forum iPad 2 Forum
    Last Post: 01-19-2012, 08:16 AM
  4. Replies: 4
    Last Post: 12-06-2011, 09:54 PM
  5. Move file from PDF PRovider to Dropbox
    By modemjunkie in forum iPad Help
    Last Post: 09-05-2011, 03:34 AM
audio from ipad to pc
how do i get my ipad audio into my
