Low battery
This is a discussion on Low battery within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi all I seem to get a low battery after switching the device on I start with 100% and within an hour im down to ...
Results 1 to 6 of 6
Thread: Low battery
    253915
    Oct 2012
    7
    Low battery
    Hi all
    I start with 100% and within an hour im down to 50
    Is there anything i can close or take off the ipad that can help maintain my battery power?
    Moderator
    235421
    616 times
    Aug 2012
    Adelaide, South Australia
    3,655
    Low battery
    Quote Originally Posted by KC 71 View Post
    Hi all
    There may not be a problem with your battery at all, just what that lazy, inconsiderant %age gauge up top may be telling you.😳
    Apple themselves recommend that you should, at least once a month, completely run down the battery and then fully charge it up again. What this does is to realign those recalcitrant delinquent little lithiums, or whatever the little devils do inside, and RECALIBRATE the %age display. That way you should get a more accurate state of your batter charge.
    Of course discharge depends also on such factors such as brightness and sound and whether your iPad is syncing automatically etc. But give the "full discharge" suggestion a go and let us know if that improved matters.
    Regards, Andrew🐨
    Please come back to say whether a member's assistance solved a problem. Others may be helped by that.
    Check out the rules~ http://www.ipadforums.net/forum-rule...ease-read.html
    iPad3 64gig black, much unused PC Win 8.1 Pro, Samsung Galaxy mobile phone, Electrolux refrigerator (cool version)
    253915
    Oct 2012
    7
    Seems to be working a bit better now thanks for the advice
    Moderator
    235421
    616 times
    Aug 2012
    3,655
    Low battery
    I'm glad about that, and thanks for the feedback.
    iPad Addict
    110082
    110 times
    Oct 2011
    Upstate, NY
    1,293
    Do you actually take it right down to zero or just to like 5% or whatever? My battery gauge seems to be pretty accurate and I only go down to around 5%-10% to calibrate. Just curious.
    iPad2 32GB WiFi / iOS 6.0
    32GB Wifi iPad 2 / OS 7.0
    Moderator
    235421
    616 times
    Aug 2012
    3,655
    Low battery
    Quote Originally Posted by s2mikey View Post
    5%-10% would be about perfect. Would not matter if you took it down to zero. Either way it's what would be considered a "full cycle discharge", a good way to keep the calibration of your battery in tip top health.
    I try do do it about every three weeks. Generally, on my usage, I recharge to full every two days when the %age is down to about 35-40% and then every 3 weeks take it down to 10-15%. My battery, well the iPad's😃, just sings!
    Regards, Andrew🐨
  1. Battery
    By jasfin123 in forum iPad 3 Forum
    Last Post: 10-25-2012, 02:23 PM
  2. How often do u charge battery to save battery life
    By eddiethebhoy in forum iPad General Discussions
    Last Post: 04-24-2012, 04:29 PM
  3. The battery!
    By normanj in forum iPad General Discussions
    Last Post: 03-07-2011, 09:40 AM
  4. Battery in IOS 4.2.1
    By skatealex2 in forum iPad OS
    Last Post: 11-29-2010, 07:07 PM
ipad 2 low battery
