connecting iPad to projector
This is a discussion on connecting iPad to projector within the iPad 2 Forum forums, part of the Apple iPad Discussions category; This has probably been asked a million times, but I'm not using the right search terms. I am a teacher. I have an iPad 2, ...
Results 1 to 10 of 12
    221687
    Jun 2012
    Texas
    5
    I am a teacher. I have an iPad 2, an iPhone4GS and a Windows computer/projector.
    Is there something bluetooth that I can purchase to connect to my computer so that I can bluetooth my iPad to my computer and into the projector and therefore move around the room with my iPad? The computer and projector are not bluetooth.
    Is there a better, different, easier, more difficult way to me to project my iPad (through the computer . .or not) and not be wired and/or standing right next to the computer. The projector is mounted to the ceiling and I can't reach it directly.
    I understand, not quite why, but that apple TV does not work on our school district wireless system.
    Thanks!
    Debbie
    247820
    7 times
    Sep 2012
    Australia
    157
    Hi Debs01.
    If your PC is a laptop it probably has already installed a Bluetooth adapter.
    If not you can buy a USB Bluetooth adapter and just plug it in.
    Generally Windows finds it and installs the driver.
    However you will have trouble convincing the iPad to "pair" with it.
    It will "pair with a bit of luck.
    However I have not been able to transfer any data via bluetooth as the iPad will still not accept the connection.
    All it does is give a message:
    "Do you want iPad to forget this device".
    Better tech people than me may get a better result.
    I hope you do and if you do, please explain.
    14255
    14 times
    Sep 2010
    Berlin, Germany
    218
    Hi Debbie,
    as I understand what you want to achieve - to mirror your iPad or present material on/from your iPad - the best and in my opinion optimal solution is to use the mentioned Apple TV.
    As the Apple TV you have does not work with your school district wireless system my next step would be to setup my own wireless system (a portable one) and test the setting - iPad - Apple TV and projector.
    There are several device on the market which will set up a wireless net. Of course, they require an additional investment of money and time. For short presentations - up to 3 hours I use Airstash (amazon link) with the additional benefit that I can store files on its internal SD card.
    For all day trainings I use a pocket wireless route like this one (amazon link).
    Both set up a wireless system which then connects to both the Apple TV and the iPad. The Apple TV connects via cable to the projector. In case your projector is not equipped with HDMI you need to convert the HDMI from Apple TV to VGA. And of course there is a device for it. I use this one. (amazon link)
    All in all - it works perfectly for me but you need to be ready to invest money.
    Hope this helps a bit.
    Knut from good old Germany.
    If you happen to be in Berlin, Germany, please let me invite you to a cup of tea, coffee or a pint of beer.
    247820
    7 times
    Sep 2012
    Australia
    157
    Hi Debbie.
    All good advice there from Kricke.
    But my plan B would be get an ell cheapo laptop with windows OS.
    Is that not how it is already set up?
    14255
    14 times
    Sep 2010
    Berlin, Germany
    218
    Quote Originally Posted by PeterJMelb View Post
    Hi Debbie.
    Yes, that's Debbie's setup, as far as I can read it.
    Except that there seems to be a need or wish to move around and to use the new technology, which I strictly and vehemmently support.
    Otherwise PC with Windows and projector make quite good a team. I would agree with you on your plan B.
    Knut
    148639
    Jan 2012
    5
    Not sure if you are connecting iPad to computer via Wifi? Maybe not as you are considering Bluetooth.
    If you are able connect via Wifi, what about keeping your current PC/projector set up and just control it via a VNC app?
    221687
    Jun 2012
    Texas
    5
    Ok…not so new at playing on my iPad, just new at making it useful for teaching. Don't know for certain what a vnc is but it almost reads like Remote Desktop. I have that working.
    Maybe I didn't explain it well. I very simply want to project my iPad on the projector. Because the computer is the only thing connected to the projector, mounted on the ceiling, I figured I'd have to go through the computer. It's not wireless and its not Bluetooth. I'll buy what I need, within reason.
    Is there an app I could put on my phone to control my iPad? Then I could leave the iPad connected to the computer and walk around with my phone.
    Thanks for your input. Please let there be an easy answer.
    126602
    Nov 2011
    Toronto
    28
    You need 3 things to make this happen: the right O/S on your computer, windows software called AppServer, and wifi in the room.
    1) Your laptop needs to be running Vista or Windows 7. Won't work with XP.
    2) You need to buy AppServer - google it, you'll find it no problem. It's $12 for teachers from what I see.
    3) You need to have wifi to connect both your iPad and your computer to. If there's on in the room, great. If not, use the personal hotspot on your iPhone.
    Then, you connect both the iPad and the computer to the same wifi network, double-tap on the iPad's home button, swipe to the right, and you'll see the AirPlay icon show up - choose your computer from that icon, set mirroring=On, and your iPad will now transmit to your computer screen. And since your computer is connected to the projector, the iPad screen will now appear on your screen.
    Not simple (at least the way I've described it!) but I know it works - I do this at home. At work, however, the wireless is a little restrictive and it doesn't work - you may find the same issue, which is why personal hotspot on the iPhone is such a blessing.
    The appserver website has good info on how to set this up - check it out. Good luck!
    iPad Addict
    168139
    51 times
    Feb 2012
    Brisbane, Australia
    1,143
    Another "low tech" option would be to buy the Apple VGA Adaptor and a very long VGA cable. Nearly all projectors have VGA input, and this is most likely the way the PC connects already. You may even have a wall plate with a VGA connection to the projector that your PC already uses.
    dhewson777
    Brisbane, Australia
    iPad 2 , iPhone 4, MBA 11"
    Yes, I have windows PCs as well! (too many to list)
    14255
    14 times
    Sep 2010
    Berlin, Germany
    218
    @ssarmazi
    Very good alternative.
    But I couldn't find appserver.
    I know two other PC/Mac programs which have the functionality mentioned. AirServer and Reflection.
    Could you please give a link to this software?
    Thanks Knut.
  1. Replies: 3
    Last Post: 11-07-2012, 08:46 PM
  2. Ipad 1 to projector?
    By 55julie55 in forum iPad Help
    Last Post: 05-03-2012, 09:40 AM
  3. Using a projector with ipad 2
    By cjparker in forum iWork Forum
    Last Post: 02-23-2012, 02:42 PM
  4. Replies: 1
    Last Post: 12-15-2011, 08:09 PM
  5. Another projector review: The AAXA P4 Pico Projector
    By fourier in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 11-09-2011, 03:34 PM
bluetooth projector for ipad
bluetooth projector ipad 2
connect ipad bluetooth projector
connect ipad to pc projector
connect ipad to projector
connect ipad to projector wirelessly
connecting ipad to a projector
connecting ipad to projector
do ipads connect to mounted projectors
mirror ipad to pc bluetooth
projector
