iPad sync problems
This is a discussion on iPad sync problems within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I've run into a problem syncing my iPad from iTunes. I'm trying to manually sync it and have that option checked. When I drag a ...
Results 1 to 7 of 7
    250300
    Oct 2012
    iPad sync problems
    When I drag a movie into the iPad (under devices) it shows up in the iPad but is shaded in grey and doesn't actually copy onto the actual iPad.. Any ideas?
    It's also showing a bunch of songs on the iPad, also shaded in grey.
    85546
    474 times
    Aug 2011
    Edmonton AB Canada
    9,500
    What are the file extensions? Sounds like they might be incompatible with the iPad, especially if you are converting mp3 to AAC. I had a couple this week that wouldn't convert, even though they were ripped from the same album at the same time.
    They appeared grayed out and I had to delete them from the iPad. I did get a message in iTunes that they couldn't be converted, though. .
    Presently using: Apple iPhone 4 | Apple iPad 2 | Apple MacBookPro | AppleTV | Apple AirPort Extreme
    250300
    Oct 2012
    Thanks for the response. I have the movies set up in iTunes and they play fine on my Mac and on my Apple TV. I believe they are .m4v files... should I be using something different to get them on my iPad?
    As there's also songs showing up under music - also shaded out in grey - I'm wondering if it's a different issue though.
    85546
    474 times
    Aug 2011
    Edmonton AB Canada
    9,500
    Maybe try changing the file extension to .mp4, although .m4v should work.
    Have you moved the songs on your hard drive? They may be grayed out because they are no longer in the same place.
    Clutching at straws here, btw.
    250300
    Oct 2012
    Thanks again.
    The songs are actually showing up greyed out in the iPad music tab when I'm in iTunes. I don't have any music on my hard drive as I use the iTunes Match/iCloud storage.
    Thinking of trying to restore the iPad to it's original settings to see if that cures things but feels like a drastic step to take.
    85546
    474 times
    Aug 2011
    Edmonton AB Canada
    9,500
    Sounds pretty drastic. I don't use MusicMatch so I'm not much use to you here.
    Good luck. Hope someone pitches in who has some experience with this.
    250300
    Oct 2012
    Thanks again for your advice. I tried the back-up and restore option tonight and it worked a charm. Not sure why I had the problem in the first place but that was a relatively quick and easy fix :-)
  1. Help with iTunes/iPad sync problems
    By pharmacist25 in forum iPad Help
    Last Post: 01-07-2012, 03:34 PM
  2. Sync Problems
    By Gorilaz in forum iPad 2 Forum
    Last Post: 01-04-2012, 01:21 PM
  3. Sync Problems :s
    By digohs in forum iPad Help
    Last Post: 05-11-2011, 12:58 AM
  4. JB ipad itunes sync problems
    By Kinghalifax in forum iPad General Discussions
    Last Post: 02-11-2011, 10:55 PM
  5. vlc sync problems
    By lanimae in forum iPad General Discussions
    Last Post: 11-01-2010, 10:31 AM
ipad movie sync issues
ipad sync problems
ipad sync problems music
ipad syncing problems
ipad video show syncing but doesn't copy
movie greyed out on ipad
movie on iphone is shaded grey
problem synka film itunes ipad
sync problems
when i sync music from itunes to iphone 4s it does not play in iphone is shaded
why are ipad music showing up as grey in itunes computer
why are synced videos showing up as grey on ipad
