iPad 2 LCD is not working, digitizer doesn't work-
This is a discussion on iPad 2 LCD is not working, digitizer doesn't work- within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I received an iPad 2, everything worked fine (LCD, touch etc), but the glass was cracked, so I decided to repair it. I bough a ...
Results 1 to 3 of 3
    248427
    Oct 2012
    I received an iPad 2, everything worked fine (LCD, touch etc), but the glass was cracked, so I decided to repair it. I bough a new Digitizer from eBay, removed the cracked one and replaced it. After, when I tried to start it, the power button didn't respond, well the battery was dead, but It didn't show up the red battery icon, where it says plug in charger. I plugged in the charger and waited for the iPad start. It started normally but the touch didn't work, It worked very poorly when i flipped the screen, but nothing more. I couldn't do anything, I thought that the digitizer I bought was broken or bad quality or something.
    The iPad was still on, I couldn't close it since the power button didn't work, (volume keys didn't work, but mute worked). While the iPad was still on I removed the digitizer and the LCD screen. Now while waiting for the new glass I ordered for the US, I put the LCD screen back and the cheap digitizer to show a friend the touch problem and now It doesn't respond at all, neither the glass or the LCD, its completely black, when I plug in the charger the beep sound comes but nothing more, I cant use the home button. normally when u plug it in, the screen show up, but now it is just dead. Is the LCD screen also broken now ?, I am starting to get panic. To repair the power/volume key, I need a new ribbon cable, witch I've ordered.
    Anyone who knows what the problem could be and how to solve it?
    138415
    Dec 2011
    26
    Mine did the same thing when I replaced mine. I bought a new LCD as well and when I plugged it in same thing still, read online that sometimes it needs to be rebooted manually to get the backlight to come back on. I had to stand in my kitchen right under the lights and was able to see the screen very very very faintly and then powered it down with the slider. Once it started back up the backlight was back on.
    262602
    Nov 2012
    Sandiego
    I changed my digitizer and when I plugged everything back in place I turned the iPad on to check if it powered up and it did just that the screen was mostly white with some likes when I click the off/on button the screen does show the swipe but really distorted any help with this?
  1. ipad 2 camera; sometimes it doesn't work
    By airhead in forum iPad 2 Forum
    Last Post: 03-30-2012, 10:20 AM
  2. iCloud doesn't work from my pc to My ipad
    By jenga in forum iPad Help
    Last Post: 01-08-2012, 08:34 PM
  3. Updated iPad, now doesn't work
    By kellypibb in forum iPad Help
    Last Post: 12-29-2011, 06:35 PM
  4. iPad display doesn't work!
    By evove in forum iPad Hacking
    Last Post: 11-21-2011, 02:25 PM
  5. Genius doesn't work on my Ipad
    By miglesiase in forum iPad 2 Forum
    Last Post: 10-27-2011, 11:34 PM
apple ipad replacement lcd display not working
ipad 2 digitizer not working after replacement
ipad 2 display not working
ipad 2 lcd not working
ipad 2 lcd not working after digitizer replacement
ipad 2 lcd screen not working
ipad 2 screen wont work
ipad digitizer doesn't work
ipad digitizer not working after replacement
ipad lcd not working
ipad2 replaced screen now dim
replace ipad digitizer but screen doesn't light up
