Results 1 to 7 of 7
    247680
    Sep 2012
    England
    Ipad 2 wifi consistently drops out
    I've seen others have similar issues but this is driving me to despair.
    I know my pad is faulty even though only 3 months old. The microphone does not work and the wifi nearly never lasts for more than 10 seconds at a time.
    This has obviously got worse since I first started using it
    Having partly known my old ISP was rubbish I put it partly down to them. Now I have good stable broadband non stop and a pad with no ability to use the wifi.
    My only option is to send the pad back for repair or replacement
    I strongly feel that apple have sold my a defective PEICE if junk that looks pretty but barely functions.
    Seriously not happy and never buying another I device again. This is the 3rd device that the wifi has died on. The others being my pod and iPhone.
    It is about time apple addressed what is obviously a major flaw with their devices.
    They go for style and size rather than cooling and performance issues..
    624 times
    Dayton, WA
    13,315
    If your wi-fi is having problems on all iOS devices check with it's manufacturer to see if it needs a firmware update. Also be sure to restart the router, and while it is down go to Settings > General > Reset, and reset All Network settings.
    iOS devices have had a lot of problems with early 802.11/n routers. Some people have simply replaced their router with a newer model.
    If you are absolutely sure it is a hardware problem, you have a one year limited hardware warrantee. But Apple will probably want to try the other solutions first.
    247680
    Sep 2012
    England
    Certain it's the hardware. My other I devices work fine. And the pad mainly has issues when it has been used for an hour or so. I'm 100% certain it's an overheating issue with the pads. The mic problem is def the hardware so will try the warranty approach if I ever get a reply from a person.
    247680
    Sep 2012
    England
    Thank you for the response. Btw. Sorry did not say that straight away.
    624 times
    Dayton, WA
    13,315
    No problem. Good luck.
    Please let us know how it turns out.
    42186
    6 times
    UK
    755
    Stand your ground and demand a replacement
    111434
    357 times
    Oct 2011
    Near the Ionian Nebula, still searching for Earth
    8,591
    If you're returning the iPad to an Apple Store near you, ensure you book an appointment, on line, with the Genius bar. Really cuts down on waiting time.
    Good luck.
  1. Replies: 13
    Last Post: 11-19-2011, 01:57 PM
  2. iPad 2 wifi connection drops intermittently....problem solved
    By Appsolutecreations in forum iPad General Discussions
    Last Post: 11-08-2011, 08:46 AM
  3. Ipad drops wifi connection
    By nickwebster in forum iPad Help
    Last Post: 07-29-2011, 07:55 PM
  4. Wifi Drops Connection When Idle
    By freescalpel in forum iPad General Discussions
    Last Post: 06-28-2011, 06:49 AM
  5. Wifi connection drops solution!
    By Itzxdjx in forum iPad General Discussions
    Last Post: 04-18-2010, 01:17 PM
ipad 2 dropping wifi
ipad 2 drops wifi
ipad 2 drops wifi connection
ipad 2 wifi dropping
ipad dropping wifi
ipad drops off wifi
ipad drops wifi
ipad wifi drops out
ipad2 dropping wifi
why does ipad drop wifi
wifi dropping on ipad 2
wifi drops on ipad 2
