Safari Autofill Not Working
This is a discussion on Safari Autofill Not Working within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Autofill (i.e., passwords, logins, etc.) has stopped working in Safari on my Ipad2. Yes, I've gone into Settings and set it up several times, but ...
Results 1 to 6 of 6
    139226
    Dec 2011
    6
    Autofill (i.e., passwords, logins, etc.) has stopped working in Safari on my Ipad2. Yes, I've gone into Settings and set it up several times, but it still won't work. I've gone on the Internet, but the entries I've found were no help. Some repeatedly told those complaining to set it up in Settings. Others merely lamented the fact their Ipad Safari didn't work either. Surely, there's a real solution - preferably, a step-by-step.
    580 times
    Dayton, WA
    13,191
    If you read up, you've probably encountered these usual fixes before, but just in case:
    Also, though I don't know why it would make a difference, make sure you don't have Private Browsing turned on, and that you Accept Cookies from Visited (found in Settings > Safari).
    139226
    Dec 2011
    6
    I tried what you recommended, but nothing worked. I use the ipad professionally, so I can't try a hard rest for about another week. After that I'll see if a hard reset will work, unless you or anyone else has a solution. Thank you for taking the time to attempt a fix.
    580 times
    Dayton, WA
    13,191
    The reset does not erase anything. It's just a more robust restart, as far as I can tell.
    A bit more drastic, but still data safe is Restore All Settings, found in Settings > General > Reset. This does not erase apps, data, or accounts, but you'll have to go though most of your settings and re-tweak to get things back to how you like them. It looks scarily like when you first set up your iPad. Just warning you in case you have a weak heart.
    What you don't want to do until you're home and have a good backup is a Restore from iTunes on the computer, or Erase All Contents and Settings from the Reset settings on the iPad. The other two are harmless, though the second can certainly test your patience if you've forgotten just where the setting you want to reset is at.
    When you are at the Reset settings page, it's not a good time to be tapping randomly by accident. Be sure to tap the right button.
    237591
    Aug 2012
    9
    same problem, I've tried everything but it does not work
    I activated it in settings, linked to my info in contact book, did reset, but still does not work (does not fill and if I press "autofill" button nothing happen)
    I guess it's a widespread issue, but for some reason I don't find solutions
    help somebody?
    Inviato dal mio iPad con Tapatalk HD
    139226
    Dec 2011
    6
    Has anyone used any aftermarket Ipad2 app that would work better than Safari and in essence, replace it?
    On my PC I use Norton which does the same as Safari, but is more reliable: you surf to a site, it autofills the site's user name and password and you're in with a click. I DON'T want anything that I have to open first, scroll around looking for a saved web link, then click, etc. I want it to work just like Safari - at least when Safari works. Also, the app needs to save new user names and passwords when entered on a new website. The app doesn't have to handle credit card info, but if it does, that would be great. And, finally, I don't want to have to have a PC version (unless free) or a yearly subscription fee. Thanks.
  1. AutoFill Eraser (Free) - Clean Up E-Mail AutoFill Entry List
    By Mickey330 in forum Jailbreak Applications & Tweaks
    Last Post: 08-03-2012, 04:37 PM
  2. Autofill not working for iPadForums
    By davidinvirginia in forum New Member Introductions - Site Assistance
    Last Post: 05-18-2012, 10:02 PM
  3. Safari not working
    By eddap in forum iPad 2 Forum
    Last Post: 02-14-2012, 02:50 PM
  4. Replies: 2
    Last Post: 01-18-2012, 01:37 PM
  5. Autofill not working (Outlook Web Access)
    By tonypitt in forum iPad General Discussions
    Last Post: 08-29-2010, 07:56 AM
autofill iphone not working
autofill not working
autofill not working in safari
autofill not working iphone
autofill not working safari
autofill on ipad 2
autofill safari not working
ipad autofill not working
ipad safari autofill not working
iphone autofill not working
safari not working on ipad
