Page 3 of 3 FirstFirst 1 2 3
Results 21 to 28 of 28
Like Tree1Likes
Thread: Ios 6 update.problems
  1. #21
    48665
    508 times
    Brisbane, Australia
    19,666
    Quote Originally Posted by hank1985
    I don't own an iPad. App Store keeps crashing on me. Has this happening you you all too
    Hi and welcome to the Forum!
    So I guess you have an iPhone? We do have a sister site called iPhone Forum and I will attach a link below.
    http://www.iphoneforums.net/
    Try closing the app store app completely and relaunch and see if that makes a difference
    From the home screen double press the home button to reveal your multi task bar. These are all the apps that you have opened at one time. Long press the app until it jiggles and a red minus sign will appear above it. Press the minus sign, this will close the app, not delete it, now press the home button to return to your screen. It's also a good idea to close all these apps, as it helps the iPad run smoothly, let us know if this makes a difference.
    iPad 2 64gb 3G
  3. #22
    246232
    Sep 2012
    Australia
    Ahhhhh I am having soooooo many issues with my app store - I don't have to re-enter my password, but it won't download anything - I've gone to update apps but they're not finishing updating - they're still "waiting", so I can't use any of them!!!
  4. #23
    48665
    508 times
    Brisbane, Australia
    19,666
    Quote Originally Posted by CassieLee91
    Have you done any iTune downloads recently? Have a look to see if there are any pending downloads in the iTunes app, if there are just swipe to bring up delete and your updates should then load....let us know if this helps you.
    iPad 2 64gb 3G
  5. #24
    255936
    Nov 2012
    Bangalore
    Quote Originally Posted by High201 View Post
    Ever since I updated my iPad 2 to iOS 6 it has been running terrible. The pages are loading up slow in safari and sometimes will not load at all. The page freezes. This happens sometimes when I go to the App Store as well. Sometimes the page is blank and other times the apps are there. I am not happy with this update at all. It feels like I am running windows. I thought this crap didn't happen to apple products. I was thinking about buying a MacBook but after this I am not so sure. Is this happening to anyone else. Thanks
    Hi, were you able to get over the problem? I am as well facing same problems after my upgrade to ios6 on my ipad2. I saw similar problems reported in multiple forums but nowhere could find a solution. With this upgrade iPad has become almost unusable for browsing. Any help or pointers for resolution are most welcome
    Regards
  6. #25
    37823
    539 times
    Cranbrook, Kent, UK
    15,671
    Quote Originally Posted by Prasanna.kota
    Regards
    Check out this thread to see if it helps Laggy after IOS 6 upgrade.
    78549
    8 times
    Jul 2011
    Oconto, WI, USA
    257
    Tis odd as I was having these lag issues also but I was jailbroken and running iOS 5.something. I had a post in the hacking section but never heard back. I just updated to iOS 6.0.1 (un-jailbroke) yesterday, 11/02/12, and I don't realize the same amount of lagginess now. Cheers, Dan
    iPad 2 32gb wifi 6.1.2 jailbroken with Evasi0n
    iPhone 4s 16gb 6.1.2 jailbroken with Evasi0n
    iPod Touch 2nd gen 32gb wifi 4.2.1 jailbroken with Greenpois0n
    "To acquire the habit of reading is to construct for yourself a refuge
    from almost all the miseries of life." W. Somerset Maugham
  8. #27
    257521
    Nov 2012
    Florida
    When I opened my Ipad last night there was an update available - IOS 6. Stupidly, I said yes, do the update. My Ipad has been "configuring" since last night, yes, that is 24 hrs. I cannot stop it, shutting it down doesn't stop it, when I open it back up the 'configuring' starts again. I don't have an antivirus on it, and I couldn't get to it to turn it off if I did. What do I do now???
  9. #28
    55606
    May 2011
    23
    Regards
    If is still slow. Sometimes stuff still does not load and sometimes when I tap on something I have to tap it more than a couple of times especially when going to the iTunes Store, etc. I just wished I never downloaded the latest version.
  1. Replies: 5
    Last Post: 01-12-2012, 01:35 PM
  2. Problems After Update
    By Shareece in forum iPad General Discussions
    Last Post: 11-01-2011, 07:46 AM
  3. ios 4.2 update problems---am I the only one?
    By jrowlett@knology.net in forum iPad General Discussions
    Last Post: 12-21-2010, 09:51 PM
  4. Did You Have Problems with iOS 4.2 Update?
    By NumbLock in forum Apple iPad Polls
    Last Post: 12-05-2010, 12:48 PM
  5. Some problems since update
    By jabba_boy in forum iPad OS
    Last Post: 12-03-2010, 01:33 PM
ios 6 ipad 2 problems
ipad 2 ios 6 issues
ipad 2 ios 6 problems
ipad 2 ios 6 update problems
ipad 2 issues with ios 6
ipad 2 upgrade to ios 6 problems
ipad ios 6 update problems
ipad is slow after ios 6 upgrade
ipad os 6 problems
ipad2 update ios 6 problems
problem updating ipad2 to ios 6
safari on ipad 2 ios 6 keeps going too slow or not at all
