Have a iPad 2 seems to have frozen up ,can't even get into AppStore...what's up? Help!
This is a discussion on Hickup within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Have a iPad 2 seems to have frozen up ,can't even get into AppStore...what's up? Help!...
Sometimes gadgets freeze....
Hold down power and home buttons together for 10 seconds and the iPad will reset. Let it reboot and you should be good to go...
Did try turning off and rebooting,,didn't work.I also can not seem to get mail up to date and my iPhone is also doing this...Ty...anything else I can try?
OK, normally when someone says the device is frozen, that means you can do nothing, zip, nada. Can you explain exactly what you mean. What happens? It's not a freeze. What is working? Sounds like your springboard (the home screens) and lock screen are working. What happens to things that are not working? Do you mean all apps are just crashing back to the home screen as soon as you start them?
Please clearly describe the exact symptoms.
My App Store took ages to open I just had a "loading" screen just give it time it will eventually load up.
iPad 2 16gb wi-fi IOS 5.1.1 (Black)
iPhone 4 16gb IOS 5.0.1 (White) - Jailbroken
First time iPad-er
Not only not connecting to I tunes,or AppStore only half FB ...it gets stuck and will not load says its loading but after minutes it's still says loading.Now that is when I check several ...seems to stall.i also sync with the OC earlier.Still seems to hold up some of the pages.Make sense.
Day 2 of can not get into app store ...iPad still acting strange...
May I suggest you go to a wifi hot spot and try again it sounds more like a Internet issue than the iPad
Cheers Colin,
Brisbane Australia
_____________________________
iPad User Guide
Forum Rules. Please Read.
Hacking Section Rules
Thank you I am going to try that but how do I do that? I am a senior and not good at this stuff.
