Ipad 2 microphone issue !
This is a discussion on Ipad 2 microphone issue ! within the iPad 2 Forum forums, part of the Apple iPad Discussions category; hello guys this my first post here ,, hope you help me ! this my 6 month old ipad 2 yup it's steel under warrenty ...
Results 1 to 7 of 7
    243317
    Sep 2012
    Egypt
    5
    hello guys
    this my 6 month old ipad 2 yup it's steel under warrenty coverage but the apple store so far from me so i need a home fix
    i have the famous micophone issue my mic recording level very low so i need to stuck my mouse into that small hole !
    so i read about that famous trick about vacuming the microphone hole by using the vacuum cleaner and i did it and it worked !!!
    i had very great quality then after couple of hours the sound started getting lower and lower tell it reached the lowest case again needs your mouth stuck to the hole it reached that in 72 h (3days) so , i did it again it took a little bit more time to do it and after it worked perfectly again ,3 days it backs again to low recording voice ! i did that 3 times and every time it go back to what it was. that takes 3 days or less
    so is there any help
    itried
    respring , reset , reboot , power off , vacuum. .. every thing works for a sometime and go back ..
    please don't tell me to restore because it's not software problem i am sure when i vacuum it some thing gots back again idk what but that what i can explain
    note: my ipad is coverd by a cover it's not smart it's looks like the case that was for ipad1 but it only have magnets !
    so please help !!
    thanks
    129720
    18 times
    Nov 2011
    474
    Why not get an ipad microphone. Google it and you will get several hits.
    85546
    472 times
    Aug 2011
    Edmonton AB Canada
    9,446
    Thanks for the PM and I'm glad you had at least partial success with the vacuum method. All I can think is that you are maybe moving the obstruction and over time it is settling back into place and causing the same physical obstruction again.
    So all I can really suggest is to keep trying the same thing again in the hope that you dislodge it and remove it completely on one attempt. Sorry I can't be of any more help, but I culled this advice from elsewhere, and have been suggesting it since it is known to work.
    Presently using: Apple iPhone 4 | Apple iPad 2 | Apple MacBookPro |
    243317
    Sep 2012
    Egypt
    5
    Quote Originally Posted by KevinJS View Post
    thanks for replying
    so how to do that !!
    what you suggest how to fix it in that place !
    you mean that i keep trying in vacuuming like that every time it get low !!
    243236
    3 times
    Sep 2012
    Riverside ca
    167
    Quote Originally Posted by eng.sameh
    thanks for replying
    I had a problem with mine.. The mike just recorded static. I finally took it back to apple and they just replaced my iPad 2 with a new one.
    243317
    Sep 2012
    Egypt
    5
    Linda ,, i can get it back to apple and catch new one but it take a lot of time and maybe the new one have a new issue i wouldn't know it
    so this one have little problem and i could solve it by vacuum every 3 days or leave it and use external mic
    the topic only for know what does makes the mic goes like that
    256120
    Nov 2012
    Apple said they will replace mine but I'm worried that it is refurbished and not in as good a shape as mine. Should I just keep mine warrenty up in a month.
  1. IPad Microphone malfunction
    By jersep in forum iPad Help
    Last Post: 06-19-2012, 09:07 AM
  2. Ipad 2 microphone problem...
    By UchihaIPAD in forum iPad 2 Forum
    Last Post: 01-02-2012, 06:45 AM
  3. Use the ipad as a microphone
    By Abrantes in forum iPad General Discussions
    Last Post: 09-20-2011, 10:34 PM
  4. iPad 2 external microphone
    By Manchoa in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-04-2011, 12:50 AM
  5. iPad 1 microphone
    By Salinda in forum iPad Help
    Last Post: 04-16-2011, 04:52 PM
how to clean ipad mic
how to fix ipad microphone
how to fix mic on ipad 2
ipad 2 mic problem
ipad 2 microphone
ipad 2 microphone not working
ipad mic not working
ipad microphone issue
ipad microphone not working
ipad microphone problems
mic problem ipad 2
microphone ipad 2
