losing wifi after sleep mode
This is a discussion on losing wifi after sleep mode within the iPad 2 Forum forums, part of the Apple iPad Discussions category; i've seen quite a few search results on this but no answers. "brand new" refurb ipad 5.1.1 no settings adjusted. after a long sleep mode ...
Results 1 to 10 of 12
Like Tree1Likes
Thread: losing wifi after sleep mode
    138379
    Dec 2011
    ny
    29
    after a long sleep mode (overnight) the ipad has lost it's wifi. not only that, the ipad is slow to respond to everything.,,,,as if it's groggy. a couple of times, it didn't "turn on" when the cover was opened....i had to tap the home button to bring up an unlock. backlight seems a bit dimmer etc etc. just in general - the ipad is not "alert". i have to restart the unit and everything is cheery again. wifi is connected, everything normal
    any clues...i've googled this. many results, no answers.
    thx
    Moderator
    131244
    618 times
    Dec 2011
    Regina,Canada
    14,488
    Quote Originally Posted by andreak View Post
    after a long sleep mode (overnight) the ipad has lost it's wifi. not only that, the ipad is slow to respond to everything.,,,,as if it's groggy. a couple of times, it didn't "turn on" when the cover was opened....i had to tap the home button to bring up an unlock. backlight seems a bit dimmer etc etc. just in general - the ipad is not "alert". i have to restart the unit and everything is cheery again. wifi is connected, everything normalY
    thx
    The public wifi at my hotel in Chicago earlier this week was like that. If the iPad went to sleep, the wifi connection was lost on wake up and had to be reconnected. I think it's more likely to be a function of the wifi router than a problem with the iPad.
    goofy8275 likes this.
    138379
    Dec 2011
    ny
    29
    Quote Originally Posted by scifan57 View Post
    The public wifi at my hotel in Chicago earlier this week was like that. If the iPad wnt to sleep, the wifi connection was lost on wake up and had to be reconnected. I think it's more likely to be a function of the wifi router than a problem with the iPad.
    yes. i read that answer elsewhere. this is my home network. my other ipad has no problems. phone and other puters on wifi are okay. it's just this ipad.
    there is nothing. the ipad is looping trying to find networks but it cannot. it doesn't populate a list of networks. essentially the wifi is like it shut off, and again the unit itself is just slow and grumpy unless i restart.
    iPad Wizard
    49745
    370 times
    6,597
    Have you tried resetting / restarting your iPad? iPhone, iPad, iPod touch: Turning off and on (restarting) and resetting
    You might also try restarting your router. My iPad lost wifi connection once for no apparent reason after I'd been staying in a corporate flat for weeks (no change in settings or password), and everything worked fine again once I reset the router.
    138379
    Dec 2011
    ny
    29
    Quote Originally Posted by Kaykaykay View Post
    yes i've said that i had to retstart my ipad to get it going again. that is not an optional solution however. i shouldn't have to do that every time the ipad comes out of sleep mode. resetting the router is no option either because my other ipad works fine. i guess i'll be contacting support. i shouldn't have to deal with work-arounds.
    what i was hoping for was if someone had a solution in settings that i'm overlooking.....thx
    iPad Wizard
    49745
    370 times
    6,597
    Agree that there's no reason to have to constantly work around. These are simply troubleshooting steps.
    If you've already tried restarting as well as resetting (some people don't know the difference and think that sleep mode is restarting or resetting), and tried restarting your modem, then you might be out of troubleshooting steps and need to talk to Apple.
    I will note that when I restarted my router for one of my iPad's wifi failure, I had three other iDevices that continued to work fine on the same wifi network -- a second iPad, as well as a touch 4 and an iPhone 4 at the time. The laptop I had on the same network never lost connection either. What I've noticed with multiple iDevices is that each has its own apparent quirks and sometimes one will hold a connection while another won't.
    138379
    Dec 2011
    ny
    29
    i have found an acceptable workaround. if i turn off wifi, i can manually turn it on when i open the cover, and it will connect immediately. it's acceptable because leaving the wifi on all the time drains battery anyway. STILL,,,it is a flaw. i'm wondering if i should take the unit in anyway.
    iPad Wizard
    49745
    370 times
    6,597
    I'd take it in. I wouldn't consider that an acceptable long-term fix. Your call, of course.
    227440
    Jul 2012
    16
    Having the same issue with my "new iPad" only started happening today, every time I wake it up no wifi. Everything else on the network is fine.
    I also find that when out & about, I often connect to wifi that show a good signal but can't get web pages to load etc.
    250703
    Oct 2012
    Re: losing wifi after sleep mode
    I have the same issue. The only thing that helps is when in reset network in the settings menu. Then I have to re enter all my info for each wifi network.
    Is there a fix?
    This is my first apple items and probably my last. Apple will not even talk to me me on the phone because my 90 days are up.
    Sent from my Galaxy Nexus using Tapatalk 2
  1. Sleep mode question ~
    Last Post: 03-07-2012, 04:07 AM
  2. Ipad 2 won't go into sleep mode
    By mwhoody in forum iPad 2 Forum
    Last Post: 11-12-2011, 10:35 AM
  3. Off or in sleep mode?
    By saflerl in forum iPad 2 Forum
    Last Post: 09-29-2011, 12:04 AM
  4. Getting mail while in sleep mode
    By Beerman in forum iPad Help
    Last Post: 06-22-2011, 09:01 AM
  5. Wifi still running in sleep mode?
    By Iamstrobist in forum iPad Help
    Last Post: 06-02-2011, 07:16 PM
how to prevent iphone from lossing connection after sleep mode
how to turn off sleep mode on ipad 2
ipad 2 loses wifi connection
ipad 2 loses wifi connection after sleep
ipad drops wifi after sleep
ipad loses internet connection
ipad loses wifi connection after sleep
ipad loses wifi connection after standby
ipad loses wifi connection when it goes to sleep
ipad losing wifi connection after sleep
ipad sleep losing wifi
when i shut off my ipad i lose wifi settings
