Connecting Ipad to TV
This is a discussion on Connecting Ipad to TV within the iPad 2 Forum forums, part of the Apple iPad Discussions category; the apple ipad adaptor an a MMDI cable...
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 28
  1. #11
    240354
    Aug 2012
    Cyprus
    11
  3. #12
    238980
    Aug 2012
    38
    Dont know what to say
    You should probably reset your ipad
    Srry for bad help but i thought it was an apple tv
  4. #13
    240354
    Aug 2012
    Cyprus
    11
    No Problem mate, Thanks for your input...Right who's next with any ideas on this little poser
  5. #14
    238980
    Aug 2012
    38
    If you are NOT jailbroken then you can reset your ipad setting without losing you data
  6. #15
    240572
    Aug 2012
    35
    Quote Originally Posted by dannyduo
    Hi everyone,
    I have just bought an Ipad 2 and tried connecting it to the tv, it worked No problem, THEN, I upgraded
    the apple software (settings in General) and since then the ipad will not connect to the tv.
    Any solutions, tips or advide would be greatly appreciated.
    Thanks for your time,
    Danny
    Danny, how are (were) you connecting it before? Bluetooth, Wi-Fi or HDMI cable connector? Either one should not have changed the way you link in, upgrade does not change your setting per Wi-Fi or BT so a little more info please
  7. #16
    240572
    Aug 2012
    35
    If that is the way you connected before it should not have changed, you are connecting the same way i do, make sure your cable isn't bent, snagged etc; I had no issues after my upgrade so it sounds like something went wrong with the adapter or cable, try resetting your IPad into DFU mode and it will restore your IPad back to factory version firmware, if it work on your tv with the old then you know it's the firmware, i highly doubt though. Good luck
  8. #17
    240354
    Aug 2012
    Cyprus
    11
    Thanks for the advice,
    I have not made any changes to the connections and checked the cables with other appliances, the problem only occurred when I upgraded to 5.1.1. The HDMI connection to the ipad is just not recognised after the new update.
  9. #18
    165310
    Feb 2012
    Danny,
    I have the same problem that you have and it is on all 3 of the IPad 2's that are in my house. Before the latest upgrade I had not issue watching movies on all of my Samsung TV's or on TV's around the world, however after none of them work.
    I use the A1388 HDMI adapter and have try many cables even on brand new TV's and still no go. I bought the adapter last Nov. in Thailand and it worked great until I upgraded to 5.1.1 in May.
    From what I have read it seems like we now have to buy a new adapter because the one mentioned above will not work.
    So I am with you wish someone could give a fix I have 30 movies on my IPads that I would love to watc othe 50".
  10. #19
    165310
    Feb 2012
    One more thing is that I do not have the TV option on any of the IPad as I did before.
  11. #20
    44796
    3 times
    Johannesburg
    255
    This definitely must be an issue with the latest update then. I don't think either one of you are gonna come right if your iPad isn't jailbroken to get this working again.
  1. Connecting from PC to iPad
    By aka_damo in forum iPad 2 Forum
    Last Post: 08-06-2012, 10:31 PM
  2. ipad not connecting help
    By abolty in forum iPad 2 Forum
    Last Post: 05-26-2012, 11:38 AM
  3. Connecting iPad to a TV
    By Ellenmac in forum iPad 3 Forum
    Last Post: 04-13-2012, 08:24 AM
  4. Connecting iPad to hd tv
    By Davios in forum iPad 3 Forum
    Last Post: 03-25-2012, 02:23 PM
  5. Connecting iPad to TV?
    By Jake872 in forum iPad General Discussions
    Last Post: 09-15-2010, 04:33 PM
connecting ipad 5.1.1 to tv
ipad 2 tv out settings
ipad 3 tv out setting
ipad not connecting to apple tv
ipad not connecting to tv
ipad tv out settings
ipad will nit connect to apple tv
tv out setting on ipad 5.1
