Results 1 to 8 of 8
    237936
    Aug 2012
    Woking, Surrey
    42
    Router Connection
    Does anyone know whether it is possible to set up a router/home hub using only an iPad! I have been told by at least one Internet provider that a disc drive is essential for set up and I do not have any other computer.
    70109
    Jun 2011
    London UK
    27
    AirPort extreme has an iPad App that will let you set it up. I believe you can also setup an AirPort Express just using Safari.
    159462
    16 times
    Jan 2012
    194
    Quote Originally Posted by Jupiter7 View Post
    You should be able to set it up via a web interface. If the device was provided by your ISP the disc is probably designed to just ask a few questions and automate the configuration process.
    I know AT&T used to provide discs to setup some of their DSL modems and approved routers that (quite literally) were just fancy displays on the PC that automatically submitted the correct information to the web interfaces of the devices.
    240572
    Aug 2012
    31
    Quote Originally Posted by joeyteel
    It sounds like you are trying to tether the Ipad,is that correct? Tethering can be done but I am not authorized to spell it out for you, good luck
    237936
    Aug 2012
    Woking, Surrey
    42
    Thank you for your suggestions. The method using a web interface sounds promising. Is that where I would enter any code that was needed to activate the router from scratch as it were? (as opposed to simply the password for joining a network).
    240572
    Aug 2012
    31
    Look up your router info on line on how to encrypt it so you are secure, do not use WEP as it is easily cracked. Once you have set up the router in order to use your IPad on the same network you have to enter the sam info on your IPad, there is advanced ways to encrypt as well, but if your not willing to read just do the basic encryption.
    237936
    Aug 2012
    Woking, Surrey
    42
    Thanks Calkid44. I obviously haven't got a router yet, but a friend who has BT Internet (and also a Mac and iPad) has and in the instructions with the router it said you need to use the disc or alternatively settle for a wired connection, which is equally not possible with an iPad.
    240572
    Aug 2012
    31
    You're welcome
  1. Wireless A/N 5GHz Router connection
    By Jduckip3 in forum iPad 3 Forum
    Last Post: 05-12-2012, 10:08 PM
  2. Can an Ipad be used with a wireless router with no computer hard wired to the router?
    By falcon6 in forum New Member Introductions - Site Assistance
    Last Post: 01-17-2012, 09:26 AM
  3. Router connection problems
    By hammer198 in forum New Member Introductions - Site Assistance
    Last Post: 01-02-2012, 08:19 AM
  4. Replies: 9
    Last Post: 04-03-2011, 07:29 AM
  5. Replies: 3
2 router connection
discussions from 2010 about ipad2 not connecting to router
joeyteel and encrypt
wireless router setup without computer
