HELP! Home Button/Dock connector
This is a discussion on HELP! Home Button/Dock connector within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi, Home button is not working. I replaced it with a brand new home button board, but that's still not the trouble. The Home button ...
Results 1 to 1 of 1
    237556
    Aug 2012
    Hi,
    Home button is not working. I replaced it with a brand new home button board, but that's still not the trouble. The Home button still will not work. However, what I CAN get to work: if I touch the left gold contact/pin on the dock connector where the home button board is supposed to hit...I get some activitiy. If I touch it with a metal tool such as a screw driver... it will flick back to the home screen or if the phone is in sleep mode it will wake it up. If I touch theright gold pin/contact...nothing happens. The pins don't *appear* to be bent or pushed down in any way. It's as if the home button board is not making proper contact with it but there's nothing in the way. I can't figure out why it won't work other than maybe the dock connector needs to be replaced. When its plugged in, itunes DOES detect it so the charging port part is working.
    Could this be a sign that I need a new dock connector and it wasn't the home button board at all? Thanks!
  1. Power Button & Home Button Sometimes Acting Weird
    By shakra00 in forum iPad General Discussions
    Last Post: 04-11-2012, 02:07 AM
  2. Replies: 9
    Last Post: 02-27-2012, 02:24 PM
  3. Is This An iPad 3 Dock Connector?
    By Maura in forum Apple iPad News
    Last Post: 07-14-2011, 12:48 PM
changed dock connector home button not working
ipad 2 dock connector home button
ipad 2 dock connector not charging
ipad 2 dock connector not working
ipad 2 home button connector
ipad 2 home button dock connector
ipad connector home button
ipad dock connector not working
ipad2 home button not working and wont charge
iphone dock connector home button
iphone dock connector home button pins
replaced dock connector now home button not working
