Keyboard problem
This is a discussion on Keyboard problem within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Please help my ipad2 keyboard just split and I can't figure out how to get the full keyboard back to normal...
Results 1 to 10 of 11
    235614
    Aug 2012
    New Jersey
    5
    Keyboard problem
    Moderator
    131244
    634 times
    Dec 2011
    Regina,Canada
    14,608
    Quote Originally Posted by XNYGRL
    Touch the key in the bottom right corner of the right hand keyboard segment. It will bring up a menu,touch the merge button. Your keyboard segments should reunite.
    You can also place a finger in each keyboard segment and draw the fingers together. This will merge the keyboard.
    235614
    Aug 2012
    New Jersey
    5
    Thank you so much...it works...how do you like that!
    195385
    9 times
    Apr 2012
    89
    There's all kinds of stuff cleverly hidden in the keyboard.
    When you press and hold a key, there are a lot of things that show up. My favorite is the "." and "," keys when held will type a quote or half quote (apostrophe).
    iPad 2 - iOS 6.1.3
    Moderator
    131244
    634 times
    Dec 2011
    Regina,Canada
    14,608
    Don't hesitate to come back if you have any other questions. There is almost certain to be someone who can answer almost any questions you may have.
    236044
    Aug 2012
    hi....please help i cannot split my keyboard.
    13576
    748 times
    Aug 2010
    Western NY state (USA)
    9,299
    Quote Originally Posted by bebz View Post
    First off, you have to have iOS 5 loaded on your iPad.
    Then, there are two ways to split the keyboard: (1) Press and hold either side of the keyboard with your thumbs and then, while still holding the press, pull your thumbs apart toward the edges. Or, (2) press and hold the keyboard key (lower rightmost key) and you should get two pop-up option, "Undock" and "Split."
    Hope that helps.
    236044
    Aug 2012
    Quote Originally Posted by scifan57
    hi...can i ask for help, i cannot split my keyboard on my ipad 2
    236044
    Aug 2012
    Quote Originally Posted by Mickey330
    Hope that helps.
    hi marily...
    i tried both but it didnt work (
    how can i load the iOS 5?
    13576
    748 times
    Aug 2010
    9,299
    To get iOS 5 installed, connect your iPad to your iTunes (on your computer - make sure iTunes is the most current, up-to-date one). Once it's connected, make a backup, as you'll need that later in the upgrade process.
    Then, on the main summary page, there should be a button that says something like "Upgrade." Select it and then sit back while iTunes does the work.
    Once it's completed, select to restore from backup and then iTunes will put your iPad back the way it was before you started - except you'll be on the most current iOS and you will be able to split your keyboard, which will be just one of the neat things that you'll find iOS 5 can do...
    Good luck.
  1. problem with keyboard and calendar app
    By alberion in forum iPad Help
    Last Post: 06-27-2011, 11:50 AM
  2. Hello From Colorado/Keyboard Problem
    By Jay Marvin in forum iPad Help
    Last Post: 06-12-2011, 08:15 PM
  3. Keyboard problem?
    By jmorton10 in forum iPad Help
    Last Post: 05-31-2011, 08:24 PM
  4. keyboard problem
    By Vegbrain in forum iPad General Discussions
    Last Post: 04-23-2011, 09:10 AM
  5. Keyboard Problem Since Upgrading to 4.2
    By RAC in forum iPad General Discussions
    Last Post: 12-13-2010, 08:41 PM
how do i get my ipad keyboard back to normal
how do i get my keyboard back to normal on ipad
i can,t get an apostrophe on my ipad
i need help my keypad split
ipad 2 keyboard problems
ipad keyboard glitch
ipad keyboard out of place
ipad keyboard outof place
ipad keyboard problem
ipad keyboard problems
keyboard in ipad is out of place
why is there a undock split pop up on ipad
