Results 1 to 8 of 8
Thread: Help!!!
    235172
    Aug 2012
    Help!!!
    Hi All,
    I need to copy 8 apps (large ones) which belong to our company only to 40 ipads. I wanted to check if there is a computer application available or any other way to quickly copy them on all 40 ipads rather than downloading them on all 40 over wifi.
    Please help.
    iPad Addict
    168139
    55 times
    Feb 2012
    Brisbane, Australia
    1,159
    I believe there is a configuration tool available for Mac OSX that deals with bulk iOS device configuration. It's in the Mac App Store, and is free if I recall.
    Yes, wireless sync could be painful for large chunky apps!
    dhewson777
    Brisbane, Australia
    iPad 2 , iPhone 4, MBA 11"
    Yes, I have windows PCs as well! (too many to list)
    235172
    Aug 2012
    Thanks for the suggestion. Unfortunately, I dont have a MAC machine. I only have IBM (Windows 7) laptops. Any windows application through which I could achieve this?
    Quote Originally Posted by dhewson777 View Post
    iPad Addict
    168139
    55 times
    Feb 2012
    Brisbane, Australia
    1,159
    Quote Originally Posted by kirsty1975
    Apple have only produced the configuration tool for Mac OSX.
    Are the iPads already getting synced and backed by via iTunes? They could be configured to update via iTunes either cabled or wireless. Download the apps once to iTunes PC, then update each iPad one at a time.
    dhewson777
    Brisbane, Australia
    235172
    Aug 2012
    Unfortunately the apps are not synching with itunes, could be as they are not bought from App Store.
    iPad Addict
    168139
    55 times
    Feb 2012
    Brisbane, Australia
    1,159
    Are the iPads jail broken? If not, the only place apps can come from is the App Store. Where are the apps right now, and what are their file extensions?
    Unless hey were made specifically for the company, therefore they should have a deployment method in place already. If that is the case, someone can talk about enterprise deployment.
    dhewson777
    Brisbane, Australia
    159462
    16 times
    Jan 2012
    194
    The iPhone configuration tool for Windows can do it. If these are custom designed apps, you'll need the deployment profile from the developer account to actually deploy them however.
    235712
    Aug 2012
    loland
    Dear kirsty,
    Having read your post and consider the problem, I think i may be able to help you... There is a simple solution to your probleme.
    The use of an ALC ray would help you copy the applications on your forty ipads in no time....
    With hope it will help you...
    A02
    ps: If need I will provide information on how to use the ALC ray.
