YouTube does not work
This is a discussion on YouTube does not work within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Good evening, I want help on my I pad 2 regarding YouTube. I want to know why is not my iPad working with YouTube. The ...
Results 1 to 6 of 6
    233952
    Aug 2012
    Riyadh
    Good evening,
    I want help on my I pad 2 regarding YouTube. I want to know why is not my iPad working with YouTube. The last video was the video " assassin's creed literal" after that my YouTube app, when opened, shows a black background.
    NOTE( my iPad is not a jail broken device and I don't intend jail breaking it)
    Thank You
    226877
    19 times
    Jul 2012
    360
    Maybe it was still on full screen? So it was left with a "blackscreen"... Or...
    Try completely closing the app (including in the multi-taskbar) then restart your iPad.
    "Utilize your day, make it as useful and fun as it can be."
    If you like a post, give a second to press the like button, people work hard to supply you with information that you need, show them a little appreciation...
    It's always handy reading this >>> Forum Rules <<<
    --Allen Salar--
    142862
    Dec 2011
    89
    Low bandwidth might be a possible culprit. Check your connection and strength. Some providers like schools will block things like YouTube.
    168527
    6 times
    Feb 2012
    NZ
    142
    Try this (from another thread w same problem)...
    Quote Originally Posted by twerppoet
    If you have not done so, try these common fixes.
    236748
    Aug 2012
    CT
    Lightbulb
    Hold down the home button ant a bottom bar of aps should come up hold down on one of the apps and bolth the apps will wiggle and there will be a red minus in the corner of all of the recent apps in the bottom bar you must then press all of the red minuses until all of the recent apps are gone especially the youtube app after that click the home button again to close that bar and then reopen youtube and it should work if that soes not work then i would next try to restart my ipad.
    236819
    Aug 2012
    It works for meeeee
  1. Youtube link from Safari opening native Youtube app.
    By bunraku in forum iPad 2 Forum
    Last Post: 11-17-2012, 06:59 AM
  2. Atomic Web Browser - Embedded Youtube Share Email Does Not Work
    By Danno2332 in forum iPad General Discussions
    Last Post: 12-11-2011, 01:55 PM
  3. Youtube hq feature won't work
    By Frederick930 in forum iPad Help
    Last Post: 07-01-2011, 11:34 AM
  4. youtube doesn't work in Ipad
    By jacppe in forum iPad General Discussions
    Last Post: 01-23-2011, 10:32 AM
  5. Youtube now betatesting html5, youtube in browser a reality?
    By Matenrou in forum iPad General Discussions
    Last Post: 06-16-2010, 05:06 PM
does youtube work on ipad
does youtube work on ipads
ipad youtube doesn't work
why does youtube not work on ipad
why does youtube not work on my ipad
why doesn't youtube work on ipad
why youtube doesn't work on ipad
youtube does not work on ipad
youtube does not work on ipad 2
youtube doesnt work on ipad
youtube not working on ipad 2
