No sound
This is a discussion on No sound within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hello, I have IPad 2 and for some reason I can hear no sound when playing videos that I have on my IPad or YouTube ...
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 31
Like Tree1Likes
Thread: No sound
    233573
    Aug 2012
    12
    No sound
    Hello, I have IPad 2 and for some reason I can hear no sound when playing videos that I have on my IPad or YouTube or any other video. When I try to turn volume up with the switch on the side it says sound effects and does not turn volume up. I can hear the face time alerts and all the ringtones and so fourth but can not on the videos. Just wandering if anyone could help me or if I needed to send it for repair. Thanks.
    85546
    477 times
    Aug 2011
    Edmonton AB Canada
    9,528
    Sounds like your speaker volume is turned down. Although there is only one set of volume controls, they actually control 4 different volume levels; ringer, speakers, headphones and Bluetooth.
    I suggest you play some music and turn the volume up. That should switch the volume controls to speaker volume instead of sound effects. Have to admit I have never seen "sound effects" come up when changing volume.
    Let us know whether or not this works. If not we will do some digging until we find out what's going on.
    Presently using: Apple iPhone 4 | Apple iPad 2 | Apple MacBookPro | AppleTV | Apple AirPort Extreme
    85546
    477 times
    Aug 2011
    Edmonton AB Canada
    9,528
    Here's something you could do right away. Go to Settings/Sounds and turn OFF Change With Buttons.
    I think you have accidentally muted your iPad, but continue to hear alerts because you have the capability to mute them turned off.
    The effect we are looking for here is that you should lose your alert sounds.
    Kim McKenzie likes this.
    233573
    Aug 2012
    12
    I tried both things you suggested and it did not work. I can put headphones in and I can hear music and videos and the volume button works perfect but when I take the out it does not work again. Man I am getting aggrevated.
    85546
    477 times
    Aug 2011
    Edmonton AB Canada
    9,528
    Can you take a screen shot of what you are seeing? Touch the volume up button then quickly press sleep/wake and home buttons together to take the screenshot while the volume level indicator is still on the screen, like this:
    Let's see what you have there, and see if we can't sort out what is going on.
    233573
    Aug 2012
    12
    Wanted to add my son downloaded a sound effect app on the iPad and I think that's when this started. I deleted the app and even took the iPad back to factory setting but still the same. Would that's have caused this some way? I also heard something about a iOS software that could cause this but not sure if that is correct. Mine has iOS 5.1.1
    233573
    Aug 2012
    12
    85546
    477 times
    Aug 2011
    Edmonton AB Canada
    9,528
    I can't see an app being able to affect iOS. The operating system is built in such a way that it's impossible. However, that leads me to ask, are you jailbroken or stock?
    233573
    Aug 2012
    12
    What does jail broken or stock mean? I bought iPad new from bestbuy.
    85546
    477 times
    Aug 2011
    Edmonton AB Canada
    9,528
    If you don't know, I'll assume your iPad is stock. Jailbreaking is the process where you mess with its innards to get more control over it. Our hacking section has all the details. It won't just happen accidentally, so it's a guarantee yours is still stock, as you bought it.
    I'm going to play around with my iPad and see if I can get the same effect on the screen that you are getting. While I play, you could try this. Close all running apps and do a reboot by following these instructions:
    Double press the home button, which will reveal the multitask bar. Long press on any app in the multitask bar, and then press the minus sign that appears on each of them. Once you have closed them all, press the home button again to bring the screen back to normal. Once you have done this, it might not be a bad idea to reboot the iPad. Hold down sleep/wake and home buttons together until the Apple logo appears, then release them and wait for the iPad to restart. This should sort out your problem apps.
  1. Sound? I've lost my sound! Help! Please
    By Hdchiky in forum iPad Help
    Last Post: 03-13-2012, 01:34 PM
  2. Replies: 0
    Last Post: 01-01-2012, 08:07 AM
  3. Bluetooth and Bose sound dock suddenly drops sound level
    By J_mccasland in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-06-2011, 11:16 AM
  4. Replies: 0
    Last Post: 03-01-2011, 12:19 AM
  5. How Do These Sound Boxes Make Sound?
    By padmeup in forum iPad General Discussions
    Last Post: 09-10-2010, 09:08 PM
ipad 2 no sound
ipad no sound effects
ipad no sound sound effects
ipad no sound youtube
ipad volume says sound effects
ipad youtube no sound
no sound effects on ipad
no sound facebook youtube videos ipad
no sound ipad 2
no sound on ipad 2
youtube sound not working ipad
youtube sound not working on ipad
