No sound
This is a discussion on No sound within the iPad 2 Forum forums, part of the Apple iPad Discussions category; A long shot and I'm not quite sure if it's been covered here. In Settings/General there is a setting called "Use Slide Switch To:" You ...
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 31
Like Tree1Likes
Thread: No sound
  1. #21
    231801
    Jul 2012
    7
    You can select the slide switch so it controls either rotation lock or mute. If it's switched to "Lock Rotation", you need to make sure you haven't muted your speakers in the switcher bar.
    To check this, go to Home screen and swipe up with 4 fingers. This obviously shows the apps bar. Now swipe the apps bar to the right (push it towards the right side of the screen) this reveals your iTunes player controls and on the far left is the Mute/Unmute button. make sure this is turned off. Slash across means muted.
    Note that if you have your Slide Switch set to Mute/Unmute, then this apps bar button will switch the lock rotation feature.
    Hope this helps, coz it sounds like the "problem" I had with my new iPad, and stumbled across my solution quite by accident...!
  3. #22
    85546
    473 times
    Aug 2011
    Edmonton AB Canada
    9,485
    That could work, but I'm worried about the lack of a button in the volume slider. I haven't been able to reproduce this.
    I'll be back online in a few hours, and I'll put some more thought into this. I can't see how it can be a hardware problem, but it might be.
    In the meantime, why not play around with the lock orientation/mute settings.
    If someone could guide you through a return to factory settings, that could be useful too, although I'd rather find out what has happened rather than hit it with the biggest hammer we have.
    Presently using: Apple iPhone 4 | Apple iPad 2 | Apple MacBookPro | AppleTV | Apple AirPort Extreme
  4. #23
    233573
    Aug 2012
    12
    I have tried all these and nothing works. I change the switch back nd forth nd nothing I have tapped home screen twice nd checked there still nothing. The volumes witch still says sound effects except when I plug earphones in then I get sound hru them nd volume switch allows me to turn up nd down. In ever used earphones in the iPad til last night only to ck sound nd it has never been in a dock. And I have no iPod app. Please help!
  5. #24
    579 times
    Dayton, WA
    13,186
    Unlikely, but check the dock port for debris. If you see any remove it carefully with something soft like a plastic toothpick.
    You can also try General > Reset > Reset all Settings. You will have to re-tweak most of your settings afterwards, but it will not erase content or delete you account information.
  6. #25
    85546
    473 times
    Aug 2011
    Edmonton AB Canada
    9,485
    That could be more useful than a factory restore, twerppoet.
  7. #26
    233573
    Aug 2012
    12
    How do I set the I pad back to factory settings.? I don't care to lose what's on it if that might fix it. Thanks everyone for all the help it is greatly appreciated.
  8. #27
    85546
    473 times
    Aug 2011
    Edmonton AB Canada
    9,485
    One of two ways. Either go to Settings/General/Reset/Erase all Content and Settings
    Or plug into your PC, open iTunes, and click in your iPad on the left side of the screen. On the default tab you will see an option to restore to factory settings.
    I suggest the second method. I'm not sure which OS you will reset to. You will want to update to 5.1.1 if you are taken back to the OS that was originally on the iPad so you may as well be on iTunes ready to do it.
    When you are given the choice of setting up as either a new iPad or from the backup of your iPad, you MUST choose the first, as whatever is causing this will be contained in the backup.
    If the problem survives this process, it is a hardware fault, as no faulty settings will carry over.
    Good luck. Let us know how you get on.
  9. #28
    233573
    Aug 2012
    12
    Well went to iTunes and did the restore but still the same. iPad is still under warranty so I guess it is going back to apple. I hate it so much I love this thing. Thanks for all the help.
  10. #29
    85546
    473 times
    Aug 2011
    Edmonton AB Canada
    9,485
    Well the next one should be better. Sorry we couldn't help, but it's almost certainly hardware.
  11. #30
    48665
    479 times
    Brisbane, Australia
    19,159
    Yes it certainly sounds like a hardware problem here and Apple is your only recourse.
    iPad 2 3G 64gb
    iPad 2 64gb 3G
  1. Sound? I've lost my sound! Help! Please
    By Hdchiky in forum iPad Help
    Last Post: 03-13-2012, 01:34 PM
  2. Replies: 0
    Last Post: 01-01-2012, 08:07 AM
  3. Bluetooth and Bose sound dock suddenly drops sound level
    By J_mccasland in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-06-2011, 11:16 AM
  4. Replies: 0
    Last Post: 03-01-2011, 12:19 AM
  5. How Do These Sound Boxes Make Sound?
    By padmeup in forum iPad General Discussions
    Last Post: 09-10-2010, 09:08 PM
ipad 2 no sound
ipad no sound effects
ipad no sound sound effects
ipad no sound youtube
ipad volume says sound effects
ipad youtube no sound
no sound effects on ipad
no sound facebook youtube videos ipad
no sound ipad 2
no sound on ipad 2
youtube sound not working ipad
youtube sound not working on ipad
