No sound
This is a discussion on No sound within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I already deleted all apps that I had downloaded. The only apps that show up in ten bar r factory installed apps....
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 31
Like Tree1Likes
Thread: No sound
  1. #11
    233573
    Aug 2012
    12
  3. #12
    85546
    473 times
    Aug 2011
    Edmonton AB Canada
    9,490
    This is different. Closing the apps in the multitask bar is not the same as deleting them, it is removing them from memory.
    I have a question. Is your iPad still in warranty, because what I have discovered so far is not good. Other discussions I have read indicate that you may have a hardware failure. However, we at not done yet. There are more things to try.
    Presently using: Apple iPhone 4 | Apple iPad 2 | Apple MacBookPro | AppleTV | Apple AirPort Extreme
  4. #13
    85546
    473 times
    Aug 2011
    Edmonton AB Canada
    9,490
    OK. For the first time ever, I have the sound effects volume available to me by turning on the Change with Buttons setting.
    However, leaving this control on does not affect my ability to control the volume of music played through the speaker. When I run the Music app and adjust the sound, the sound effects control is replaced by the speaker volume one, and when I turn it off, the sound effects control is back.
    Now we just have to find what is stopping your audio volume from appearing.
  5. #14
    85546
    473 times
    Aug 2011
    Edmonton AB Canada
    9,490
    Best place to start, I think, is to turn off the Change with Buttons capability in Settings/Sounds. Then we will lose the sound effects volume control and can concentrate on the other stuff.
  6. #15
    233573
    Aug 2012
    12
    I tried that and still not working. I hope not nothing major. I don't understand how everything works perfect except the video sound but I have no clue about this stuff. Going to bed now but will check back with you in the morning. Thanks for all your help and I pray when can get it fixed without sending it in. Thanks again.
    Chris
  7. #16
    85546
    473 times
    Aug 2011
    Edmonton AB Canada
    9,490
    OK. Check back tomorrow, and we will try to sort this out.
  8. #17
    233573
    Aug 2012
    12
    I turned off the change with buttons.
  9. #18
    85546
    473 times
    Aug 2011
    Edmonton AB Canada
    9,490
    OK. With music playing what happens to the slider in the music app when you adjust the sound with the up and down buttons?
    For now I'm not too interested in whether you have sound or not. I want to see if your iPad is responding as it should in other ways. Just press play and see if the slider moves.
  10. #19
    233573
    Aug 2012
    12
    When I push play it does not show the circle on the volume indicator. It just has a line a cross
  11. #20
    48665
    479 times
    Brisbane, Australia
    19,202
    Quote Originally Posted by Cciscammell
    Kevin is out of Internet range at this time but will be back later.....
    You say you've had headphones connected to your iPad, have you turned off whatever was playing before pulling out the head jack? This can cause the sound to mute, so plug them back in and actually stop the music before disengaging and see if this makes a difference. Also some headphones have a mute button feature on them, could this have been activated?
    Lastly have you had a Bluetooth keyboard attached at all? As these also have a mute button and you will need to reconnect to disable this feature.
    iPad 2 3G 64gb
    iPad 2 64gb 3G
  1. Sound? I've lost my sound! Help! Please
    By Hdchiky in forum iPad Help
    Last Post: 03-13-2012, 01:34 PM
  2. Replies: 0
    Last Post: 01-01-2012, 08:07 AM
  3. Bluetooth and Bose sound dock suddenly drops sound level
    By J_mccasland in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-06-2011, 11:16 AM
  4. Replies: 0
    Last Post: 03-01-2011, 12:19 AM
  5. How Do These Sound Boxes Make Sound?
    By padmeup in forum iPad General Discussions
    Last Post: 09-10-2010, 09:08 PM
ipad 2 no sound
ipad no sound effects
ipad no sound sound effects
ipad no sound youtube
ipad volume says sound effects
ipad youtube no sound
no sound effects on ipad
no sound facebook youtube videos ipad
no sound ipad 2
no sound on ipad 2
youtube sound not working ipad
youtube sound not working on ipad
