Results 1 to 3 of 3
    233024
    Aug 2012
    Brisbane
    Move appointment to different calendar?
    Can anyone help? I'm trying to move some items from my main calendar into the birthday calendar? Also, it calls my main calendar Googlemail, but i don't recall setting it up like that? And how do you add a new calendar, such as Work? Sorry if I'm being a bit dim, new to iPad......
    Any help appreciated
    148239
    2 times
    Jan 2012
    142
    Go to Calendar app and open. In the upper left corner touch the Calendars button. the Show Calendars menu will open. Hit the edit button to add a calendar. Here is a link with a great tutorial on setting up and selecting calendars: iPad Week: Setting Up Calendars - Nicholas Jackson - The Atlantic you can download the manual here: http://manuals.info.apple.com/en_US/ipad_user_guide.pdf which also gives a great guide to everything iPad
    Hope that helps
    624 times
    Dayton, WA
    13,312
    The built in birthday calendar takes it's data from the Contacts app, and you have to add the birthdays there. If you want a Birthday calendar that you can edit in the Calendar app you'll have to create one from scratch.
    If you are using GMail, as your post suggests, you'll need to set your GMail account up as an exchange account, and follow the Multiple Calendars setup. Instructions for both are in the below link.
    Setting up Google Sync with your iOS device - Google Mobile Help
    You won't be able to create new calendars for GMail on the iPad. You'll have to do it on the Google Calendar site, and then use the syncing instructions in the above link to sync it to the iPad. You can add/edit/delete events as normal once it is set up.
    If you are using an iCloud account, or just local calendars tap the Calendar button, then the Edit button and choose Add Calendar
    I don't recommend using the Calendar app locally only. It is easy to lose important data when it is stored in just one place, especially a mobile device.
  1. Deleting appointment in calendar
    By Lefty921 in forum New Member Introductions - Site Assistance
    Last Post: 07-27-2012, 06:39 PM
  2. Replies: 0
    Last Post: 07-12-2012, 05:48 PM
  3. Replies: 2
    Last Post: 03-19-2012, 07:32 PM
  4. Replies: 3
    Last Post: 01-07-2012, 07:15 AM
  5. Replies: 3
    Last Post: 07-30-2011, 04:28 AM
how to change the appointment in iphone from one calendar to the other
how to move calendar with ipad
how to move events from one calendar to another on ipad
ipad calendar move items to other calendar
ipad move event to different calendar
iphone 5 move an event to a different calendar
iphone calendar items move to another calendar
iphone move appointment to different calendar
iphone move appointments between calendars
iphone move calendar items
iphone move events between calendars
move calendar entries on iphone to another calendar
Tags for this Thread
