Have u try restore it??Originally Posted by KenNewHampshire
This is a discussion on How to fix iPad 2's home button unresponsive problem? Help. within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Originally Posted by KenNewHampshire It was fixed for about 2 hours ... Then it stopped working ... So disappointed Have u try restore it??...
Uhh, i also do alot of alternatives to fix this that i saw through the web, but still it has a intermittent home button.Originally Posted by TheRemedyMe
Mine too pal, I tried recall rating the home button and mine is also still acting up. Unfortunately like me it's a trip to the apple store. Hopefully I can get them to replace it instead of fixing it.
Is it a hardware problem? But mine never fall on the ground.
If the earlier suggestions in this thread did not work, then it is probably a hardware problem. No matter what product you use, there are always some hardware failures; even if you never drop it.
If the iPad is less than a year old, or you have AppleCare, then you should still be under the hardware warrantee.
https://selfsolve.apple.com/agreementWarrantyDynamic.do
Apple should repair or replace the iPad for free. If not you'll have to pay to have it fixed; either through Apple or a third party repair facility. Be sure to research any third party repair to make sure they are accredited and reliable.
Edit: I don't see your country/location, so you should double check the warrantee info. Some countries have mandatory two year hardware warrantees.
