hi i was decideing whether to go for the galaxy s 3 or an iphone and decided on th s3 as there was no iphones available at the price plan i wanted want i want to know is can i transfer my music from itunes to the s3 thanks
This is a discussion on itunes music transfer to none iphone help within the iPad 2 Forum forums, part of the Apple iPad Discussions category; hi i was decideing whether to go for the galaxy s 3 or an iphone and decided on th s3 as there was no iphones ...
If you music is on your computer in a separate file and not in your iTunes library you should be able to transfer. Please remember this is an iPad forum not an iPhone forum. You may have better luck posting your question here: http://www.iphoneforums.net/
How I do this. I connected my iPad with my pc and the only file I see is the camera roll and it won't let me transfer nothing.
iTunes my friend. It does the transfer for you.Originally Posted by dw1064
dhewson777
Brisbane, Australia
iPad 2, iPhone 4, MBA 11"
Yes, I have windows PCs as well! (too many to list)
So let's see if I have this correct, you went to buy an iPhone , but got an S3 instead , you downloaded iTunes from the apple webpage and now you're asking on an Apple iPad forum how to synch music to your Samsung S3 phone using Apple iTunes?Originally Posted by Gunneruseipad2
