"Unable to join" wireless network...calling all network gurus....
This is a discussion on "Unable to join" wireless network...calling all network gurus.... within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I see. That is administrator protected. I'd rather ask the companies IT's permission and say something creative that would make work more productive. Other than ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
  1. #11
    45904
    11 times
    Philippine
    595
    I see. That is administrator protected. I'd rather ask the companies IT's permission and say something creative that would make work more productive. Other than that, I doubt. I have secured my CCTV's and would be impossible for others to hack in. Safety reasons.
  3. #12
    229100
    Jul 2012
    8
    I've had problems with mixed 802.11b+g+n bandwith on routers. It often helps to choose only one of those if your ios device has problems, but remember to choose one that all devices can use. In these cases the g standard seems to be the safest.
    Regards
    Jon Leirdal
  4. #13
    159462
    16 times
    Jan 2012
    194
    Quote Originally Posted by leirdal
    Regards
    Jon Leirdal
    That was already tried. That's what the speed setting he mentioned changing on the router actually changes
    Quote Originally Posted by quake5254
    The wife already has permission. He mentioned that in the first paragraph
  5. #14
    221170
    Jun 2012
    16
    Quote Originally Posted by joeyteel
    Joey, thanks for backing me up here. Per your suggestion, I'll check Mac filter switch.
    My wife is actually the tech head in the office when it comes to computers. It only falls to me when she is unable to work out the problem. I had permission enough to be poking around in the router config, but again, did not want to compromise anything as there are medical records involved, so security takes absolute precedence.
    Looks like rooting the phone is looking more and more like the way to accomplish this. I never imagined that wireless connectivity would be all that difficult to achieve. I haven't tried yet, but I'm pretty sure I could drag my laptop in and it would jump right on....I might have to do that to keep working the problem.
  6. #15
    229100
    Jul 2012
    8
    Quote Originally Posted by joeyteel View Post
    I noticed he said he had tried going down to 54, but that means he still can be running both b and g, thats why I mentioned it.
    Anyway, I can't help much more than that little fact. It's a tricky one to solve. Some routers just are anoying and need to be replaced.
    Regards
    Jon Leirdal
  7. #16
    221170
    Jun 2012
    16
    Had to work late today, but I think I may have found a solution in the "guest" network option . If we can get the ok to turn that on, configure with some less restrictive settings (lower level encryption, single band mode, etc. ) that would just pass internet and not allow network access (since for her ipad there would really be no immediate need to do that. I had hoped to have a little more time (did not quite get it working),, but that might be the ticket. Not a direct fix; more a workaround, but I'll take what I can get at this point.
  8. #17
    215170
    9 times
    Jun 2012
    Cape Town
    389
    The only solution is to briefly turn of wifi security, test turn on , then try Mac filter off under wifi, then firewall off , and if the router has it turn Mac filter off under firewall.
    Last some routers support ip range filtering.
    Another thought is the DHCP setting could be set to limiting only say 10 computers , and the iPad is the 11th so no ip address , or there is no DHCP and it is all static IP.
  1. No Service "Could not activate cellular data network"
    By ignatzthecat in forum iPad 2 Forum
    Last Post: 04-02-2012, 01:05 PM
  2. Unable to join the network [name of network]
    By tnbarbara in forum iPad 2 Forum
    Last Post: 03-03-2012, 09:56 AM
  3. iPad 2 Unable to join network ...
    By kkwong in forum iPad Help
    Last Post: 08-14-2011, 02:51 PM
  4. iPad 2 Unable to join working network.
    By BobHelms in forum iPad Help
    Last Post: 08-04-2011, 01:10 AM
  5. unable to join a network.
    By KATZ49 in forum iPad Help
    Last Post: 07-04-2011, 04:43 AM
failed to join network iphone
ipad unable to join network
ipad unable to join wireless network
netgear unable to join network
unable to join network ipad
unable to join network netgear
unable to join network on ipad
unable to join the network netgear
unable to join wireless network iphone 5
unable to join wireless network on ipad
why am i unable to join a network
