Ipad 2 / Speed Test
This is a discussion on Ipad 2 / Speed Test within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hello all....just did one of those speed tests here...U Tube always stopped and started. Have the Verizon DSL... Both 5GHZ and the 2.4 were..... Ping ...
Results 1 to 10 of 12
    11187
    Aug 2010
    NJ
    106
    Ipad 2 / Speed Test
    Ping 75MS
    Download 0.70MBPS
    Upload 0.13MBPS
    Is this really to slow for decent video?
    Our TV is wireless and does the same thing on videos....Netflix and so on
    Thanks!! Ken
    148239
    2 times
    Jan 2012
    142
    The answer to your question is YES that is really slow.
    177736
    20 times
    Mar 2012
    UK
    282
    As the previous poster stated, the speeds you are getting is very slow, and very likely too low for viewing video without severe buffering.
    Mine is not super fast but my download speed over wifi is approx 15mb with upload being 0.94mb. That's with TalkTalk in the UK, my wired connection to my PC is 18.5mb d/load.
    If I was you, I would have a look to see what other ISP's can offer in your area, I used to get very slow speeds when I was on Sky, at busy times I was unable to stream anything from the net. I now get much better speeds at half the price I was previously paying, so it really does pay to research what alternatives there are... You may be pleasantly surprised....good luck.
    iPad Ninja
    49414
    80 times
    North Carolina
    1,930
    Hi Kenworth - just to confirm the opinion given already - I ran the 'speed test' on my iPad (we have cabled Road Runner as our ISP).
    Ping, 99ms; Download, 4.32 Mbps; and Upload, 0.78 Mbps - these are my usual speeds, and I've had no major issues w/ using Pandora internet radio or streaming movies from Netflix or Amazon (using my Roku device). I'm also using an older Linksys router, 802.11 b/g and still have streamed HD films w/o a problem.
    Just a couple of questions: 1) Have you been streaming movies and having problems?; 2) If so, HD or standard resolution for the films?; and 3) Have you power recycled your modem & router?
    141426
    Dec 2011
    17
    Sorry to jump on this thread but Lunar mentioned something that I have been trying to find an answer to. Hem entwined he was getting 15mb down but 18.5mb when wired. Is this normal? I get about 10 wired and only 6.5 on my iPad. Strangely enough I also seem to get better speeds wirelessly on a windows pc than on any Mac product (mb pro, iPad and iPhone). Is there something in apple's settings that slows things up?
    Cheers, Steve.
    iPad Ninja
    49414
    80 times
    North Carolina
    1,930
    Hi Steve - well, this is a complicated question, especially w/ the Wi-Fi standards so numerous and changing to achieve higher transmission rates - wired 'fast' ethernet is rated at 100 Mbps (of course, not usually achieved); the Wi-Fi 802.11 a/b/g/n protocols have widely varying speeds - I have a b/g router so my maximum 'wireless' speed would be 54 Mbps; now the n standards offer potential speeds of a wired connection.
    But out of interest, I just ran a speed test on my 'Wired PC' (w/ fast ethernet card), VISTA laptop, & iPad (re-tested) - the results are shown below (top row is the ping test, second the download speed, and lower the upload values). First, my wired computer was best at the ping & download tests; second, the VISTA laptop was better than the iPad in those same categories (note that both were tested in my den chair using the same Wi-Fi router in the adjacent room). Now, I'm not sure why my iPad 2 had only half of the DL speed?
    Wired PC Vista Laptop iPad Re-Test
    29 ms 39 ms 79 ms
    31.0 Mbps 19.3 Mbps 8.8 Mbps
    0.98 Mbps 0.98 Mbps 0.93 Mbps
    45904
    11 times
    Philippine
    595
    Your download speed should be at least a 2.0mbps to get a decent viewing. Check www.pingtest.net
    177736
    20 times
    Mar 2012
    UK
    282
    Quote Originally Posted by s_tevep View Post
    Cheers, Steve.
    Further on this...I've noted that sometimes my wifi speedtest Will be a bit higher up in the 16.5mb range occasionally touching 17mb download 15.5 is probably the slowest I get. Strangely my wife's Acer laptop seems to perform equally well whether its connected by wifi or cable, though it's generally used close to the router, as being a couple of rooms away from the router can also affect speeds somewhat.
    Also the type/brand of router can definitely affect speeds, I'm using a fairly new N router, where my older router was about 3mb slower.
    One has to bear in mind that the speed itself can vary slightly so should be taken as a guide, also having other wifi devices in the home will affect speeds, ie phones ect. But generally ime a wired connection will generally give better speeds, which is why my PC and PS3 are both wired, though obviously again that can vary depending on the network card in the PC ect.
    I would have thought you need close to 2mb to get stutter free video streaming and much more for HD.
    141426
    Dec 2011
    17
    Thanks Lunar. I've tried my MacBook pro wired and things speeded up a bit so that must be it.
    231210
    Jul 2012
    India
    Yes, It is slow. For the speed assistance, you can place a gadget to check your internet speed anytime which is available at Scanmyspeed.com free of cost.
  1. Speed Test
    By oldertwin in forum iPad General Discussions
    Last Post: 02-21-2013, 03:09 AM
  2. Reliance Mobile iPad speed Test
    By virendrak in forum iPad Carriers
    Last Post: 02-26-2011, 01:43 AM
  3. iPad vs iPhone speed test
    By Wakawaka in forum iPad General Discussions
    Last Post: 02-13-2011, 03:27 PM
  4. iPad speed test tether
    Last Post: 02-03-2011, 02:17 AM
  5. Speed test Ipad vs iphone3gs
    By Pogi-pad in forum iPad General Discussions
    Last Post: 05-21-2010, 02:07 PM
how to check internet speed on ipad 2
internet speed ipad 2
internet speed test for ipad 2
ipad 2 speed test
ipad speed test
ipad wireless speed
speed test for ipad
speed test ipad
speed test ipad 2
speedtest for ipad 2
wireless speed test ipad
