Ipad 2 wifi speeds - Wireless n
This is a discussion on Ipad 2 wifi speeds - Wireless n within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Good day all, New here, so hope i posting on correct space. I would like to know at what speeds the ipad 2 can connect ...
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By leelai
Thread: Ipad 2 wifi speeds - Wireless n
    91600
    Aug 2011
    Good day all,
    New here, so hope i posting on correct space. I would like to know at what speeds the ipad 2 can connect to Wireless n network? I have a netgear dgnd3700v2 router, with 5ghz network st up. But wifi scanner says it connect at only 54mb? Is this software glitch? What other mac tool /ipad tool can i use to verify?
    Thank you in advance for asistance,
    ________________________
    An Apple a day, keeps the Gate(s)keeper away...
    48665
    485 times
    Brisbane, Australia
    19,286
    Hi and welcome to the Forum!
    Have a look at an app called Speedtest, hope this is what you're after.
    iOS5 Tips and Tricks
    iPad 2 3G 64gb
    jhyjhy likes this.
    iPad 2 64gb 3G
    18578
    10 times
    Oct 2010
    Virginia, usa
    608
    The 5Ghz is the frequency of the radio frequency use to communicate between wireless devices, not the speed of the download. Your 54mb is a good download speed depending on local conditions. Best case would probably be approximately 90-100mb, you won't see this very often, usually much lower, again everything depends on local conditions.
    Good Luck
    Pocobear
    91600
    Aug 2011
    Thx for info.
    215170
    9 times
    Jun 2012
    Cape Town
    389
    54Mbits/sec is fast, nothing wrong with it, you can stream video no problem, however depending on signal strength it can drop down below 10mbsec.
    138414
    Dec 2011
    United States
    86
    I gave up on the 5gz frequency all together. It's just not a consistent connection unless your really close to the router or not many walls to penetrate. I get a much faster and more consistency from my dual band when staying clear of the 5gz line.
    Greygoose
    iPad Ninja
    49414
    80 times
    North Carolina
    1,930
    Quote Originally Posted by Makwassie View Post
    Good day all,
    Hi Makwassie - welcome to the forum!
    There seems to be some confusion about the Wi-Fi standards (i.e. IEEE 802.11 a/b/g/n) - first concerning the broadcast frequencies, the two main ones used are 2.4 GHz & the 5 GHz bands; 802.11 a & n can use both, whereas b & g are limited to 2.4 GHz; I have an older Linksys b/g router in my house, so the 2.4 GHz band is being used (of course different channels can be selected but not broadcast frequency). Thus, the frequency(s) being used by your router depend on which lettered protocol(s) are supported.
    Now concerning your 54 MB quote above - I'm assuming that you mean Mbps (i.e. Megabits per second) - I just ran the Speedtest on my iPad2 and my download speed was 14.4 Mbps; now if I had a 5 GHz router, I'm assuming that the number would be much higher; 802.11 g can transmit up to 54 Mbps, whereas the n protocol can send up to 3x faster; SO, if you are indeed getting 54 Mbps, that is pretty good!
    Also keep in mind that download (and upload which is typically slower) speeds will depend on other factors, including your ISP connection and speed, distances between the router and your device, and interference issues, such as walls.
    101550
    Sep 2011
    This thread comes up high in the list of searches for this, so I figured I would post a tidbit here in case anybody else runs into this issue.
    All currently existing iPads are limited to roughly 30mbit streaming capacity due to corner cutting in the wifi hardware. This makes it impossible to stream most higher end bluray content without downsampling it. Apparently the iPad uses a single rail so it isn't capable of full n bandwidth.
    I ran into this issue while trying to stream Avatar to my iPad 2. At first I thought it might be a signal issue, but it was working fine with all of my android devices.
  1. Connect my wifi ipad to my wireless tether app from phone
    By accordlayingkit in forum iPad General Discussions
    Last Post: 09-22-2012, 04:37 PM
  2. Connect ipad with pc - wireless or wifi
    By georgevj in forum iPad Help
    Last Post: 12-24-2011, 11:11 PM
  3. Replies: 0
    Last Post: 12-18-2011, 11:24 AM
  4. how fast is your wifi ipad speeds?
    By mrdinh in forum Apple iPad Polls
    Last Post: 09-23-2010, 10:49 PM
  5. iOS 3.2 VS 3.2.1 wifi speeds
    By MikesTooLz in forum iPad OS
    Last Post: 08-07-2010, 02:47 PM
ipad 2 download speed
ipad 2 n router
ipad 2 wifi speed
ipad 2 wireless n
ipad 2 wireless n 5ghz
ipad 2 wireless speed
ipad wireless n
ipad wireless speed
ipad2 wifi speed
max wifi speed on ipad 2
what is the downloading speed of ipad2
wifi speed of ipad 2
