Easy itunes question for the pros
This is a discussion on Easy itunes question for the pros within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Finally decided to try hooking my iPad up to iTunes and attempt to transfer some movies that I have in m4v format from the pc ...
Results 1 to 4 of 4
    138414
    Dec 2011
    United States
    86
    Finally decided to try hooking my iPad up to iTunes and attempt to transfer some movies that I have in m4v format from the pc to the iPad .. Easy enough ... Right?
    Here's what happens... I copy the file from the pc folder and do a paste into my default itunes library called movies. Seems to cut and paste just fine. But when I do a "sync" , nothing happens.....
    I am able to do a direct copy and paste straight into the "movie" area that comes up under my iPad in devices and the movie appeared in my video folder without performing a sync. Aren't things in the library suppose to sync with the corresponding folders in the device?
    Am I doing something wrong?.... I have the preference setting to not sync automatically, but that shouldn't cause this behavior. So in the end, I got what I wanted to accomplish completed, but wanted to try and get a better handle on this iTunes thing.
    When I Transfer music in my iPod, I put it In The music library and it seems to sync just fine to the music area under the device.
    Btw....none of this media was purchased through iTunes store.
    Any explanation concerning this would be helpful.... Thanks for everyone's input on some of my previous matters.....
    Greygoose
    138414
    Dec 2011
    United States
    86
    May have answered my own question here. I believe you need to turn on the sync feature from the menu across across the top . Sounds like I need more practice.
    Thank
    Goose
    148239
    2 times
    Jan 2012
    142
    Your right. You need to check the 'sync movies' box. Also instead of copying and pasting, try using iTunes - 'File' in the menu bar and on the drop down 'add file' or 'add folder' option which will bring up a menu to add files or entire folders to your library. Sync and they they are.
    Banned
    179253
    Mar 2012
    USA
    25
    Active “sync movie” function and try again to sync from iTunes.
  1. Quick and easy question,no matter what you recon
    By michae222 in forum iPad OS
    Last Post: 06-26-2012, 03:04 PM
  2. Pros and cons?
    By ITGeekLondon in forum iPad Hacking
    Last Post: 05-29-2012, 03:41 PM
  3. Complex question with an easy solution.
    By Hunkabilly in forum iPad Help
    Last Post: 01-26-2012, 05:07 PM
  4. Safari question ....easy copy and paste
    By shackleton in forum iPad Apps
    Last Post: 01-23-2012, 06:20 PM
  5. Need help from the pros
    By borsuk48 in forum iPad General Discussions
    Last Post: 09-14-2011, 04:00 AM
easyitunes ipad
why aren't the videos pasting in my itunes
