Anyone can help me please?
This is a discussion on Anyone can help me please? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; 2 problems 1: Anyone know the reason why my ipad was muted when im using FaceTime? 2: when friends call in there are no ringing ...
Results 1 to 7 of 7
    222198
    Jun 2012
    2 problems
    2: when friends call in there are no ringing tone as well.
    is my ipad got problem or the setting not set up properly?
    i still can play youtube , videos or I pod music.
    please advise .
    thanks !
    85546
    576 times
    Aug 2011
    Edmonton AB Canada
    9,849
    Check the side switch. If you can see an orange dot it is set to mute, although music will still play.
    Apple Equipment (so far) rMBP 15"; iPad 2 (iOS 7.1); iPhone 5s (iOS 7.1); iPhone 4 (iOs 7.1); AirPort Extreme; Airport Express; AppleTV
    222221
    Jun 2012
    England
    I had this problem and it was because the screen lock/mute button on the side of the pad at the top right hand side was locked. Switch it and try again. It is next to the volume rocker button. I think it has something to do with how you have set this button up in settings. Look under lock rotation, mine is set to mute.
    85546
    576 times
    Aug 2011
    Edmonton AB Canada
    9,849
    If it is set to "lock rotation" and was previously set to "mute", it will still mute system sounds.
    In this case you need to change it back to "Mute", then switch it off. You can then switch it back to "Lock rotation".
    48878
    2 times
    Denver, CO USA
    16
    Or just double tap Home, slide to the left, and unmute there.
    You don't have to switch the side switch back to mute control in Settings.
    222198
    Jun 2012
    Thank you all for your kindnss reply . i have a picture attached of my setting and my side switch was not in orange color.
    weird!
    thanks !
    222198
    Jun 2012
    thank you all ! i've manage to off the mute already.
    thanks again
face time on ipad is muted
helpme plese
