Slow ipad 2
This is a discussion on Slow ipad 2 within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi everyone, I hope someone can help me because my iPad 2 has gone really slow on everything I do. 1st time on this site ...
Results 1 to 4 of 4
Thread: Slow ipad 2
    216065
    Jun 2012
    Slow ipad 2
    Hi everyone, I hope someone can help me because my iPad 2 has gone really slow on everything I do. 1st time on this site so would really appreciate some help. Thanks
    191583
    Apr 2012
    5
    I am new at this also, but did you check what applications you have open.
    Double click the main button and a bar will open on the bottom of the screen. This will show you what you are running.
    Touch and hold on of them to make them jiggle and then Delete any you do not want running.
    Don't worry you still have the applications, they just stop running.
    Try that.
    216065
    Jun 2012
    I've done that but still not made any difference. The touch screen reacts about 1•5 seconds after I've touched it so can't play games now because of reaction time
    13576
    1444 times
    Aug 2010
    Western NY state (USA)
    11,051
    It may be that you need to do a restart or a reset of the iPad2 after closing all the apps. To do all that:
    Fully Close an App: Double tap the Home button (or do a 4-finger swipe up) to reveal a row of icons in the multi-tasking bar. Press and hold an icon until they all start to wiggle and you see a red circle with a minus sign ("-") in the top left. Press the minus sign to fully close the app. Don't worry, it won't remove the app from your iPad, just from the iPad's resident memory.
    Then...
    See if that helped fix your slowness problem. If no, then do this:
    Reset: Hold both the power and home buttons until the screen goes dark and the Apple logo then appears (the slide to unlock screen may or may not appear). Once the logo appears, release the buttons. After a time, your homescreen will appear. Please note that it may take some time for the Apple logo to appear or for your homescreen to appear (or both). This is normal. Eventually, the homescreen will appear.
    As much as Apple likes to tell us different (or downplay it), the iPad is just a computer and so sometimes needs a swift kick in the software. So, see if this helps.
    Good luck and do let us know how you get on.
  1. iPad Photos so slow
    By djtrix92 in forum iPad 3 Forum
    Last Post: 03-29-2012, 12:05 AM
  2. Slow ipad
    By Njzillest in forum iPad General Discussions
    Last Post: 09-19-2011, 01:22 AM
  3. iPad so slow.
    By Flypoppa in forum iPad 2 Forum
    Last Post: 09-05-2011, 05:09 PM
  4. iPad slow
    By nana49er in forum iPad Help
    Last Post: 08-18-2011, 06:46 PM
  5. my iPad has gone slow please help!
    By Burley89 in forum iPad Help
    Last Post: 07-16-2011, 01:49 AM
ipad 2 is slow
ipad 2 slow
ipad 2 sluggish
ipad2 slow
slow ipad
slow ipad 2
slow ipad2
sluggish ipad 2
