Ipad not charging ?
This is a discussion on Ipad not charging ? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; hi forum, i have an ipad model A1395.. my original charger broke so im trying to use my ipod 3rd gen adapter to charge my ...
Results 1 to 10 of 15
    215424
    Jun 2012
    ny
    Question Ipad not charging ?
    hi forum, i have an ipad model A1395.. my original charger broke so im trying to use my ipod 3rd gen adapter to charge my ipad but it states not charging ,i also tried to connect to my cpu -usb port and it says not charging on top of screen on my ipad ???could this be a dead battery ?thank you for reading my question.
    191975
    Apr 2012
    8
    An iPad charges very, very slowly from your computer. You should charge it from a wall outlet using the power adapter.
    215471
    Jun 2012
    Oak Ridge, TN
    Battery @ 100%, plugged in to PC to get everything up to date/transfer, new iPad3 64g bought today, it says not charging. is that because its @ 100%, so it doesn't over charge it?
    Thanx
    577 times
    Dayton, WA
    13,181
    Few PCs supply enough current at the USB port to properly charge an iPad. Most newer computers will charge the iPad, slowly, if you are not using it (screen off, at the least).
    The average PC port supplies about 5W. The power supply that comes with your iPad supplies 10W. The new iPad is more power hungry than the iPad 2. It will probably lose battery if you use it while plugged into a computer's USB port, and take most of a day to charge even if off. And by day I mean 24 hours.
    You are best off using the power supply that came with it. If you need a second power supply, like for the car, make sure it is rated for 10W (5V at 2A approximately).
    215471
    Jun 2012
    Oak Ridge, TN
    Wow! thanx for the quick reply, i didnt know it was such a power hungry machine! dang. i just bought it and left it hooked up to my laptop to transfer a lot of stuff. i hope its still alive after 12-13hrs till i get home in the morning. of course i will go home and try to sleep and then spend the day playing with my new "toy", good thing its supposed to rain tomorrow!
    577 times
    Dayton, WA
    13,181
    No problem.
    As long as you did not set it so the iPad's screen stays on, you should be fine. Even then, the power loss would be slow, so you should still be fine.
    Have fun.
    215471
    Jun 2012
    Oak Ridge, TN
    Thanx poet! i guess ill find out in about 6 hours! lol. have a good night on the west coast.
    iPad "3" 64g WeFe, iPhone 4 32g Verizon, AppleTV
    577 times
    Dayton, WA
    13,181
    You're welcome.
    What do you know! It is dark outside.
    215601
    Jun 2012
    5
    Lately My ipad can't charge...they said it's hardware problem...it's still under warranty.anyone have the same problem?
    215601
    Jun 2012
    5
    Quote Originally Posted by love my ipad
    But if i'm using usb cable and charge from pc it's WORKS even it's shown NOT CHARGING....
  1. iPad car GPS charging?
    By Allgoodpeople in forum iPad 3 Forum
    Last Post: 05-22-2012, 03:06 PM
  2. Charging the ipad
    By Tassiecelt in forum iPad General Discussions
    Last Post: 05-16-2011, 10:44 AM
  3. Replies: 7
  4. ipad not charging
    By Matt cooper in forum New Member Introductions - Site Assistance
    Last Post: 02-11-2011, 10:42 PM
  5. Charging while ipad is off
    By ali70 in forum iPad General Discussions
    Last Post: 08-08-2010, 05:58 AM
how can you see ipad charging if screen is broke?
ipad 1 not charging
ipad 1 says not charging
ipad 2 says not charging
ipad a1395 charger
ipad a1395 disabled not charging
ipad a1395 not charging
ipad model a1395 battery
ipad model number a1395 charger
my ipad says not charging
why ipad says it's charging but
why my ipad said not charging
