Not Able to Save PDF on iBooks anymore
This is a discussion on Not Able to Save PDF on iBooks anymore within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Dear Friends, I have an Ipad2 and since some days ago I have some problems to save on IBooks most of pdfs that arrive by ...
Results 1 to 6 of 6
    213453
    Jun 2012
    Dear Friends,
    I have an Ipad2 and since some days ago I have some problems to save on IBooks most of pdfs that arrive by email.
    I have spoke with a lot of Apple techicians and nobody knows why...
    Anyone with the same issue?
    Regards,
    David
    142862
    Dec 2011
    103
    I dunno the answer. I was wondering if there is a PDF or iBooks memory limitation at all. I normally keep mine in different subject folders, and they are in a separate section from the books. Do you think it might be in another section?
    250769
    Oct 2012
    Washington
    I have had the exact same problem for the past few weeks. Started when IOS 6 came out. I can no longer open PDF attachments in either iBooks or in GoodReader. I could be IOS 6 came out.
    Went to the genius bar at the downtown Portland Apple store. They didn't have a clue. Suggested I send in a bug report to Apple. Did that two weeks ago and have heard nothing.
    Other threads suggest you could delete iBooks (and GoodReader) and reinstall them. Tried that. No good.
    Until Apple sends an upgrade to fix this bug we're stuck.
    1523 times
    Walla Walla, WA
    15,432
    Quote Originally Posted by carol49
    This thread is considerably older than the advent of iOS six. Several people have reported this Open In problem after thier iOS six update, but a reset or restart has fixed it for most. Give them a try if you have not.
    Reset: Hold down the power and home buttons until the Apple logo appears. The iPad will reboot. This usually takes a bit longer than a restart. takes a bit longer than a restart.
    252183
    Oct 2012
    Brisbane, Australia
    not just iBooks having problems saving since ios6
    I've been having the same issue on the new ipad since ios6 (some pdf's not saving from email into iBooks).
    I've also had another app crashing out saving data after ios6 upgrade - until vendor issued an update via App store. I'd say there is a bug in ios6. Waiting for an update... very annoying as I use these pdfs to avoid carrying around lots of hard copy documents at work.
    277712
    Feb 2013
    I have the same problem, but I just choose the second option "Open in.." And there I select ibooks and this works for me.
  1. Replies: 13
    Last Post: 04-11-2012, 11:31 AM
  2. Replies: 2
    Last Post: 01-14-2012, 08:22 AM
  3. Replies: 1
    Last Post: 08-21-2011, 06:47 PM
  4. Replies: 2
    Last Post: 07-19-2011, 05:03 AM
apple forums ipad 2 ibooks
email pdf from ibooks
how to save a pdf on ipad 2
how to save pdf on ipad 2
pdf not saving in ibooks
pdf to ibooks
save pdf in ibooks
save pdf to ibooks
Tags for this Thread
