Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Mickey330
Thread: Icons lost after Absinthe 2.0 Jailbreak
    213033
    Jun 2012
    I upgraded to OS 5.1.1 on my iPad 2 to Jailbreak using Absinthe 2.0.
    I followed following steps -
    1. Made a backup of iPad 2 in iTunes. Subsequently, I went to Settings – General – Reset – Erased all Content and Settings.
    2. Ran latest Absinthe 2.0.4; Jailbreak completed; I could see Cydia icon on my iPad2.
    3. I returned to iTunes to restore my backup. All of a sudden, I couldn't see Photos, Mails, Settings, Cydia, Camera on my iPad 2 while all other items got synced successfully.
    4. I now felt the only option as to Restore my iPad 2 using iTunes. But it gives 3194 error. I cann't see Cydia hence don't know what SHSH blobs are saved already.
    5. Tried running Absinthe again - it says "Device already Jailbroken! Detected Stash. ".
    I will appreciate help for getting these icons back. Nothing comes up even if I search in Spotlight for these - Photos/Mails/Cydia/Settings.
    13576
    803 times
    Aug 2010
    Western NY state (USA)
    9,449
    Before you tried all this, was your iPad2 already jail broken? Because you can't do the erase all from the Settings app on an iPad that is already jail broken...
    To which iOS were you trying to restore? The only iOS you can put on is iOS 5.1.1. Try connecting your iPad back again and when it appears in iTunes, press the Restore button. iTunes should take of the rest.
    If you still have problems trying to restore, have a look at this link (Failsafe Method to Restore Current iOS): TUTORIAL - Failsafe method to restore the current version of IOS
    If you are having trouble, then if you follow the steps in this tutorial exactly, you should end up with an iPad2 on iOS 5.1.1, which will be ready to re-jailbreak with Absinthe.
    Good luck and let us know how you get on.
    danky likes this.
    213033
    Jun 2012
    Appreciate your quick response, Mickey.
    My iPad2 was not jailbroken before I tried above steps. I am trying to restore to iOS 5.1.1 by selecting the .ipsw file. However, I get error 3194.
    I will go through your link.
    thanks again.
    213033
    Jun 2012
    Mickey, It worked! I am now Jailbroken. :-)
    I had to edit the hosts file to get this working, so glad now ! Thank you very much.
    Regards,
    Ankur
    214987
    Jun 2012
    Hey Ankur - I am facing the exact same problem as you did. Can you share with me how you fixed it? You mentioned that you edited hosts file - how to do that/what to change?
    Thanks a ton.
    213033
    Jun 2012
    Below is excerpted from Point no. 2 of the link Mickey provided: - (Either Use Tiny Umbrella or Do following)
    if you know what the "hosts" file is and how to edit it manually, remove ALL references to gs.apple.com from the file and save it.
    • On Windows the hosts file can be found in: C:\Windows\System32\drivers\etc\hosts
    • On OSX the hosts file lives in /private/etc/hosts
    Now manually restore in iTunes and you shall be done!
    Ankur
  1. How to un-jailbreak iPad 3 from Absinthe 2.0.4
    By santoshsingh77 in forum iPad Hacking
    Last Post: 09-24-2012, 04:03 AM
  2. Replies: 5
    Last Post: 07-26-2012, 02:37 AM
  3. Replies: 11
    Last Post: 02-11-2012, 09:55 AM
  4. Almost 1 million i-devices using Absinthe jailbreak?
    By iDan in forum Apple iPad News
    Last Post: 02-02-2012, 01:37 AM
  5. Replies: 1
    Last Post: 01-22-2012, 01:51 PM
all icons disappeared after jailbreak
all icons missing after jailbreak
apple apps missing after jailbreak
erase jailbroken ipad 2
iphone icons disappeared after jailbreak
missing apps after absinthe jailbreak
missing icons after jailbreak
no settings icon after jailbreak
settings gone after jailbreak
settings icon missing on iphone after jailbreak
settings missing after jailbreak
