Has anybody else experienced this or similar, your ipad 2 suddenly switching itself off when the battery gets down to around 40%? Any tips much appreciated!
This is a discussion on iPad 2 battery, always switches off when it gets down to 40% within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Has anybody else experienced this or similar, your ipad 2 suddenly switching itself off when the battery gets down to around 40%? Any tips much ...
Seems that it might be related to battery calibration.
Do you charge to 100%?
Sent from my Galaxy Nexus
No, on iPad 1 and 2 my batteries work fine. I get battery warnings at 10 and 5 percent and the iPads auto-shut down at 2 percent.
As bat0nas says, your battery calibrator might be wonky. Apple advises draining your iPad battery once a month to keep the battery calibrator accurate.
If that doesn't work, I suggest you consult Apple. Your battery should still have plenty of life even if you've used your iPad 2 a lot in the past year or so that iPad 2 has out.
