TV Show Goes Missing After Synch
This is a discussion on TV Show Goes Missing After Synch within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I have the iPad 2, version 4.3.5, 32GB, not jailbroken. I have purchased and downloaded a TV show episode from iTunes directly to my iPad. ...
Results 1 to 5 of 5
    44760
    Houston, TX
    86
    I have the iPad 2, version 4.3.5, 32GB, not jailbroken. I have purchased and downloaded a TV show episode from iTunes directly to my iPad. It plays just fine as a TV Show in the Videos application on the iPad. Until....I synch the iPad via USB to my PC. After the synch, the TV show no longer shows under Videos on the iPad, and the TV Shows label is not there. The TV episode does appear under TV Shows in the iTunes Library on my PC. And I can play the show on my PC from iTunes. But it does not synch back to the iPad. In order to get the episode back on my iPad, I have to re-download it (via WiFi) on the iPad; this takes about 40 minutes. After which it shows again under Videos/TV Shows. And, when I later again synch, the episode disappears again. Since I paid for it the first time, I do not have to pay for it again, but it is a nuisance to have to re-download it each time after I synch. I did a search in the forum, but did not see my precise problem mentioned. Would appreciate any guidance to prevent the synch from deleting my TV episode.
    John Hanley
    Houston, TX
    iPad 2 user since 4-7-2011
    111434
    524 times
    Oct 2011
    Near the Ionian Nebula, still searching for Earth
    9,407
    Maybe that item got unchecked in iTunes.
    Are you on manual or auto for iTunes content?
    44760
    Houston, TX
    86
    Quote Originally Posted by AdmiralAdama View Post
    In iTunes on my PC, the item labeled 'Sync TV Shows' is checked, and to 'Automatically include all episodes of all shows'.
    Not sure where to look to see whether I am on 'manual or auto for iTunes content'. When I plug in the USB cable to the iPad, the Sync commences automatically, is that what you mean?
    John Hanley
    Houston, TX
    111434
    524 times
    Oct 2011
    9,407
    If the sync all is checked then the content should transfer to the iPad. Strange. Is there an Apple Store in your town? A trip to the Genius Bar is always rewarding. You can also sign up for free tutorials.
    44760
    Houston, TX
    86
    I have Applecare and talked to them about this issue. They helped me troubleshoot and it seems the problem is tied to Standard Definition vs High Definition video. I have downloaded an SD version of the shows and they do not disappear when I sync, but the HD version does disappear. There are still some oddities going on; for example, if I download from iTunes on the PC, there is only an HD version available and that will not sync to the iPad; if I download directly to the iPad, there is a choice betwee SD and HD, so I am using the SD version on the iPad. But at least I have a version that does not get deleted upon syncing. I will see how this works out in future, but that is where it stands now.
    Sent from my iPad 2 using iPF
    John Hanley
    Houston, TX
  1. Using i-Tunes to Synch
    By carolc1 in forum New Member Introductions - Site Assistance
    Last Post: 04-29-2012, 12:06 AM
  2. Missing "Show all open tabs" icon in Safari
    By Joesaiditstrue in forum iPad Help
    Last Post: 10-30-2011, 03:11 PM
  3. Synch stops
    By stoneybroke in forum iPad General Discussions
    Last Post: 10-09-2011, 05:34 PM
  4. Not able to synch
    By Salinda in forum iPad Help
    Last Post: 06-02-2011, 05:04 AM
  5. Getting TV show names to show up on iPad
    By SailorDave in forum iPad General Discussions
    Last Post: 11-29-2010, 09:37 PM
downloaded tv show on ipad but then it disappears
how do i transfer tv shows from itunes library to ipad
ipad missing tv shows
ipad tv show missing
itunes tv shows disappear
missing tv shows ipad
the tv show i purchased disappeared from ipad
tv shows missing from ipad
tv shows missing on ipad
why the purchased tv shows in ipad disappear
