Flickr Problems
This is a discussion on Flickr Problems within the iPad 2 Forum forums, part of the Apple iPad Discussions category; is anyone else having problems with uploading pictures from an iPad2 using iPhoto I just cannot get it to work despite have deleted the app ...
Results 1 to 2 of 2
Thread: Flickr Problems
    137433
    Dec 2011
    Flickr Problems
    is anyone else having problems with uploading pictures from an iPad2 using iPhoto I just cannot get it to work despite have deleted the app and then reloaded it. The upload freezes every time.
    Any help would be greatly appreciated.
    577 times
    Dayton, WA
    13,177
    Try the usual, if you have not done so. Also, be sure you have a good internet connection.
  1. Flickr to iPad
    By azonie in forum iPad 3 Forum
    Last Post: 03-22-2012, 11:22 PM
  2. Taking picture from Flickr to Facebook
    Last Post: 03-21-2012, 07:47 AM
  3. Flickr Photo Explorer Free
    By shiyunhe in forum iPad App Announcements
    Last Post: 02-08-2012, 03:41 AM
  4. flickr hd iPad app gets price cut to $0.99 for Holidays
    By T84 in forum User News Submissions
    Last Post: 12-22-2011, 04:36 AM
  5. Who's on flickr?
    By mikeos in forum Off-Topic
    Last Post: 04-01-2011, 11:17 AM
flickr bar problem
flickr for ipad 3
flickr ipad problems
flickr ipad uploading problems
flickr on ipad 1
flickr on ipad problems
flickr problem iphone
ipad iphoto to flickr problemss
iphoto issues uploading to flickr
iphoto problems flickr
problems uploading to flickr from iphoto on ipad
