Download problem with ipad 2
This is a discussion on Download problem with ipad 2 within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi, i am using my ipad 2 it is wifi only and i am getting 3g through a galaxy y i have been using an ...
Results 1 to 5 of 5
    206624
    May 2012
    Hi,
    i am using my ipad 2 it is wifi only and i am getting 3g through a galaxy y i have been using an app for tracking the data usage, i have been using that app for 20 days
    and now i all of a sudden this morning my data usage app in the galaxy y keeps running on its on without even me using the internet i have checked and none of the apps were updating neither was the os.
    i have tried updating to ios 5.1.1 and the meter is still running on the data usage app on my galaxy y what should i do
    is there some bug or virus causing my ipad 2 to increase data usage on its own ???
    please help
    97693
    498 times
    Sep 2011
    Michigan. USA
    15,239
    Hi there- any time an app goes weird it's best to completely close it.
    Have you tried to do the following?
    Do the first 2 steps first. Save step 3 as a last resort.
    1. Force the app to close?
    2. Try to restart your iPad?
    3. Try to do a soft reset?
    You can try this in order, if an app becomes funky.
    Force the app to quit by pushing the home button twice to bring up your multi-task bar. This will show all the apps that you have visited. By long pressing the app in question, it will begin to jiggle-press the red circle with the negative sign on the app. It will only quit the app and not delete. Than try to re-open the app and test out.
    Third is to do a soft reset by holding the power switch and home button together until you see the apple logo. Hope that helps!
    206624
    May 2012
    I have closed all apps and restarted the iPad still the same problem
    97693
    498 times
    Sep 2011
    Michigan. USA
    15,239
    Have you checked to see if there was something going o with your galaxy which you are obtaining you wifi from?
    92087
    Aug 2011
    Dear Hannibal,
    I faced exactly the same problem which is identical to the date of your posting. I also use galaxy y and 3g watchdog app. I solved this yesterday after 3 days. I have subscribed to National Geographic magazine (annual). The automatic download of June issue is happening on its own. (I usually download such heavy ones on home cable broadband.)
    After going to settings - store; there is a list of apps which automatically update the content. We need to turn these OFF to stop data usage like this.
    The confusion is because the ipad does not switch off download even when the Store tile is switched off. Apple needs to rectify this. This also happens when once we start updating OS.
  1. Download problem
    By draonclaw in forum iPad Help
    Last Post: 03-16-2012, 02:35 PM
  2. Download ipad update problem
    By Luketaytay in forum iPad Help
    Last Post: 08-10-2011, 12:06 PM
  3. Download problem!
    By Scoobaru in forum iPad Help
    Last Post: 07-30-2011, 02:04 PM
  4. Download problem
    By Grumps in forum iPad Help
    Last Post: 03-11-2011, 04:28 AM
  5. App Download Problem
    By ggildeme in forum iPad General Discussions
    Last Post: 10-17-2010, 06:05 PM
downloading in ipad problem
having trouble downloading national geographic magazine on ipad
ipad 2 download problems
ipad 2 downloads problem
ipad 2 issues downloading magazines
ipad 2 problems 2012
ipad download issues
ipad download problem
ipad download probleme
ipad downloading problems
ipad magazine download problems apple forum
national geografic ipad probleme
