Going around in circles...
This is a discussion on Going around in circles... within the iPad 2 Forum forums, part of the Apple iPad Discussions category; After looking up countless posts on the net for the no sound issue I now find my issue to be on the home screen on ...
Results 1 to 8 of 8
    206169
    May 2012
    After looking up countless posts on the net for the no sound issue I now find my issue to be on the home screen on the left where the music area is there's no volume slider....
    I did a hard reset then a software reset and both show no sound for anything....music games, videos and etc...
    Any idea on the no sound/slider bar issue
    13576
    1460 times
    Aug 2010
    Western NY state (USA)
    11,075
    So, when you double click on the Home button to reveal the multitasking bar (or do the four-finger swipe up trick), then swipe to the right to reveal what's on the left, you don't see this:
    Attachment 16322
    Could you post a screen shot of what you DO see? And, what generation of iPad running what iOS version do you have? Because I've never seen this and I'm afraid that if your iPad has "lost" this function that you may have to restore it or take it to the Geniuses at the Apple Store for assistance. Because normally - that sound slider is just there...
    161788
    Feb 2012
    6
    Can you explain in greater detail, as I don't seem to have this function either. Am I missing something?
    37823
    748 times
    Cranbrook, Kent, UK
    17,132
    Quote Originally Posted by fairline
    To reveal your iOS version number, follow these images.....
    To expose the audio controls, double tap the home button (the round physical button on the front of your iPad)......
    Attached Thumbnails Attached Thumbnails Going around in circles...-image-4054765508.jpg
    33574
    26 times
    Feb 2011
    Levittown pa
    676
    Quote Originally Posted by darrenvox
    This problem has been known to be caused by dust/lint/other debris in the dock connector port or headphones port.
    There are numerous suggestions on how to clean it ranging from a sot of compressed air to using a toothbrush to clean the port.
    Try cleaning both and see if problem persists.
    33574
    26 times
    Feb 2011
    Levittown pa
    676
    There is also a known bug with in app sound, unsure if it applies but worth a try.
    Settings/general/set side switch to.....set to mute.
    Now mute the iPad from the side switch
    Now unmute the iPad from the side switch
    Now test to see if problem persists.
    161788
    Feb 2012
    6
    Thank Gabrial1. Sorted.
    206169
    May 2012
    I'd have to be true here I accidentally dropped the iPad in the top the other night... Today i had a bit of sound from games but none from movies or stuff
  1. Replies: 1
    Last Post: 12-12-2011, 07:18 AM
  2. icloud and photostream has me going in circles!
    By Trellaine201 in forum iCloud
    Last Post: 11-09-2011, 01:50 PM
  3. Replies: 4
    Last Post: 11-17-2010, 03:06 PM
i lost the sound bar on my ipad2
ipad 2 sound not working dock connector
ipad no volume slider
ipad volume bar missing
iphone 4 volume slider missing
soundbar gone on ipad
toothbrush volume bar missing on iphone
volume slider missing on iphone 4
