Maps keeps crashing
This is a discussion on Maps keeps crashing within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I. Does anyone have the same problem as I am having. Recently the maps has been crashing. When I start it up you will see ...
Results 1 to 4 of 4
    202002
    May 2012
    Maps keeps crashing
    I. Does anyone have the same problem as I am having. Recently the maps has been crashing. When I start it up you will see the map, then the screen will turn back, and then after about 20 seconds, it will display the lock screen. Sometimes after a few hours I can access it again, sometime it can take a day? Anyone have any solutions to rectify this? Thanks
    33574
    24 times
    Feb 2011
    Levittown pa
    678
    Quote Originally Posted by raymondmc9
    Close background apps (maps specifically in your case).
    Double press home button and task bar appears with recently used apps.
    Long press any of them until it wobbles and displays a red minus sign.
    Tap the red minus sign(s) to remove app from RAM
    Tap home button to return to desktop
    Test maps
    202002
    May 2012
    Hi, thanks for your reply. I clear out the tray all the time as I know having lots of apps running affects the battery. On some occasion this does work, other times, I need to leave it alone and it works the next day, annoying to say the least! I have checked it again just then and is working again!
    33574
    24 times
    Feb 2011
    Levittown pa
    678
    Hmmm....consensus is its a problem with your contacts....
    Try the below remedy (credit apple support forums)
    pflaeging
    Re: Maps.app crashing on iPad
    Nov 12, 2010 8:18 AM (in response to kkpro)
    I've got the same problem with crashes of the map app. My solution was very simple and fast. The problem seems to be problems with the contact list. So here's my solution!
    1. Connect to iTunes
    2. Sync your iPad
    3. go to the Info Tab in your iTunes iPad Device part (don't know how to describe it better;-()
    4. check the cross under Advanced: "Replace contacts on this iPad"
    5. check "Apply"
    After this everything is working for me.
    (Sorry, I'm using my system in german, so maybe my backtranslations in english are not correct!)
    eter
    iPad 32GB wifi+3G iOS 3.2.2
    Like (0)
  1. Replies: 9
    Last Post: 11-08-2011, 03:18 AM
  2. Using Maps for a GPS
    By mjla1715 in forum iPad Help
    Last Post: 10-10-2011, 09:19 AM
  3. Upgrade Your Native Maps Application With 'Dashboard For Maps'
    Last Post: 08-29-2011, 04:45 PM
  4. Saving Google Maps User Generated Content on iPad Maps
    By sandis01@yahoo.com in forum iPad General Discussions
    Last Post: 09-27-2010, 07:30 PM
  5. how do I transfer Google My Maps user content to ipad "Maps"
    Last Post: 09-27-2010, 04:43 PM
google maps keeps crashing on ipad
google: ipad keeps crashing applications
ipad 2 keeps crashing
ipad apps keep crashing
ipad keeps crashing
ipad maps app crashes
ipad maps app crashing
iphone maps keeps crashing
maps ipad keeps crashing
my ipad keeps crashing
my ipad keeps crashing apps
why does my ipad keep crashing
