Available space problem
This is a discussion on Available space problem within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hello I am trying to help my wife out. She has had an ipad 2 for a few months. Today she was unable to use ...
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 35
Like Tree3Likes
Thread: Available space problem
    198684
    May 2012
    23
    Hello
    I am trying to help my wife out. She has had an ipad 2 for a few months. Today she was unable to use the camera. It says "Cannot take Photo. There is not enough disk space to continue taking photos. Make room by deleting existing video or photos". So we went to the "Photos" gallery and deleted around half of them - but alas it still gives the same message, and under settings->General->About, it shows Capcity:14GB and Available: 0 bytes. We also tried deleting some apps (mainly games that were pre-installed I think) but this hasn't helped either. I have tried to reset/reboot with home+sleep button for 10 secs, but this does not help either.
    If anyone could provide some advice I would be very grateful.
    LR
    33574
    24 times
    Feb 2011
    Levittown pa
    678
    Quote Originally Posted by longrob
    Hello
    LR
    What version of ios Is running on this iPad? Need to know as obtaining storage data varies.
    198684
    May 2012
    23
    Thanks for your reply. I know very little about computers - in the General->About, it shows Version 4.3.5 (8L1) and Model: MC979TH : does this help ?
    33574
    24 times
    Feb 2011
    Levittown pa
    678
    Was it synced to iTunes recently?
    198684
    May 2012
    23
    I'm not sure what that means, but we don't use itunes much - not for a month or so anyway. My wife just uses it for talking to her friends and playing games.
    33574
    24 times
    Feb 2011
    Levittown pa
    678
    4.3 provides little detail on storage on the iPad itself. Categories counts and cumulative storage totals.
    iTunes will provide more granular info on storage usage.
    Open iTunes and attach your iPad via the cable. Once you do it may sync depending on how iTunes is configured. In any case you will see storage info on a horizontal bar chart on the bottom of the screen. I believe you can drill into the categories from there to determine what can be deleted.
    Bear in mind sync settings will repopulate media objects...music, movies, pics to the iPad if so configured under iTunes preferences.
    So if you want to delete from iPad but keep on PC be cautious with how the settings are configured and from where you delete the objects to c,ear space on the iPad.
    198684
    May 2012
    23
    Thanks again.
    "attach your iPad via the cable" Do you mean the power cable for recharging the battery ? That's the only cable we have as far as I know...we've never connected it to a PC before. Please advise. Thanks.
    33574
    24 times
    Feb 2011
    Levittown pa
    678
    Thanks again.
    Correct. Unplug cable from A/C adapter, this exposes a USB connector that you plug into your PC.
    Odd if iPad was never connected...but I digress...
    On PC make sure you have current version of iTunes installed then connect the iPad with iTunes open.
    33574
    24 times
    Feb 2011
    Levittown pa
    678
    To simplify....my guess is video is chewing up your space. Delete videos not pics and space will free up quickly.
    198684
    May 2012
    23
    We don't have iTunes on our PC. I don't understand how this is relevant. Do I have to install it on the PC ? It doesn't even have an internet connection.... confusing... please advise.
  1. Replies: 0
    Last Post: 12-14-2011, 10:02 AM
  2. Space bar
    By Nuria in forum iPad Help
    Last Post: 09-26-2011, 07:25 PM
  3. How Much Space Have You Used?
    By ipfuser55 in forum iPad 2 Forum
    Last Post: 05-07-2011, 04:20 AM
  4. Replies: 8
    Last Post: 01-25-2011, 11:43 PM
0 bytes available ipad
0 bytes available iphone
deleted all app but still no space ipad
ipad 0 bytes
ipad 0 bytes available
ipad 2 0 bytes available
ipad showing 0 bytes available
ipad storage 0 bytes available
iphone 0 bytes available
iphone says 0 bytes available
iphone storage 0 bytes available
o bytes available on iphone
Tags for this Thread
