Charging battery w/o cover...
This is a discussion on Charging battery w/o cover... within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Read somewhere it was advisable to remove iPad 2 from cover when charging, for heat considerations. Have done that a few times and question the ...
Results 1 to 2 of 2
    195385
    20 times
    Apr 2012
    122
    Have done that a few times and question the value.
    What do you do and think?
    iPad 2 - iOS 7.1
    193958
    26 times
    Apr 2012
    Alba
    399
    Never had a heat problem while charging, so far.
    CLOSING APPS: If an app has stopped responding or closes on launch, try the following: * Home screen * click the Home button twice * Tap and hold on the app * When it jiggles, tap the (-) to close it * Double-click the Home button and re-open the app
  1. Battery charging
    By Switchatko in forum iPad Help
    Last Post: 03-23-2012, 08:07 AM
  2. Charging a New Battery
    By Solaris in forum iPad General Discussions
    Last Post: 11-03-2010, 09:20 AM
  3. I don't see that green battery charging....
    By SweetPoison in forum iPad Help
    Last Post: 10-25-2010, 09:21 AM
  4. charging the battery
    By Mexicat in forum iPad General Discussions
    Last Post: 07-14-2010, 03:31 AM
  5. Battery charging
    By Seadog in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-05-2010, 09:29 PM
charging ipad with cover
charging the ipad with cover open or closed
do i need to remove cover before charging battery of ipad
do i remove ipad case when recharging battery
do you need to remove ipad case when charging?
do you remove ipad from its case when charging
ipad take out of case when charging
ipad with cover while charging
remove ipad from case before charging
remove the ipad from the case before charging
should the cover be removed from ipad when charging
should you have ipad cover open when charging
