Using the iPad 2 as a satnav for the first time on Sunday
This is a discussion on Using the iPad 2 as a satnav for the first time on Sunday within the iPad 2 Forum forums, part of the Apple iPad Discussions category; On Sunday I am driving up from London to central Scotland. A trip I do about 6 times a year. This time just for the ...
Results 1 to 10 of 17
    128943
    Nov 2011
    London now. Scotland soon.
    29
    This time just for the hell of it. I am using the iPad 2 as a satnav. I have the 'NavFree' app. And have already ascertained that the iPad will successfully pair with my iPhone on Bluetooth. So no sim card will be necessary.
    My only misgivings are the weight of the iPad in the windscreen fitting cradle. Will it last the 436 mile journey?
    NavFree is a free app. But if the trip is successful, I will purchase the speed camera and 'ad free' upgrades. If it fails, then I will just have to go back to using the Garmin.
    Black Ipad2 16gb Wi-Fi & 3g. Black iPhone 4 16gb. iMac 21.5", Lion OS
    186862
    Apr 2012
    46
    Quote Originally Posted by Callander
    I use navfree as well in lreland..works well but I would be worried about the weight a bit..get yourself a good bracket and a car charger..mount it well ..enjoy..
    64 gb ipad2 in black
    128943
    Nov 2011
    29
    Thankyou.
    I have found a 'ventilator grill' fitting bracket, on eBay, which I might consider.
    The only problem is where exactly to place it.
    186862
    Apr 2012
    46
    Thankyou.
    Try and get a windscreen mount or a dash board mount if you can..iPad is a bit heavy for vent mounting..I think personally other 2ways are better
    174129
    Mar 2012
    Cyprus in the med
    68
    A photo of the iPad mounted in your car would be good.
    128943
    Nov 2011
    29
    I have looked in all the local Halfords. No luck there.
    I have a Renault Scenic II. The dash is enormous. I am considering making something from scratch.
    128943
    Nov 2011
    29
    Also, I am concerned that 'NavFree' has a bit of an 'as the crow flies' complex. I did a couple of dummy runs to Scotland, using the 'shortest' and then the 'quickest' routes.
    Both times, it ignored nearby trunk roads and motorways. Preferring to travel in as near a straight line as possible through rural and residential streets.
    I should say. I don't really need a sat nav to get to Scotland anymore. But I do find the speed limits and the safety camera positions reassuring. Plus, the Garmin which I have always used up until now, does have built in Bluetooth.
    37823
    479 times
    Cranbrook, Kent, UK
    15,236
    Just to clarify, you mentioned that as you are pairing to your iPhone then you won't need your sim card. The GPS function which is built into the 3G/4G circuitry does not require the 3G or 4G to be connected as it is standalone. So you don't need to pair with your iPhone for the GPS to work.
    128943
    Nov 2011
    29
    I did originally wonder about that. But didn't see the logic of it working in such a way. I will be thrilled if it does work, particularly in the Highlands.
    37823
    479 times
    Cranbrook, Kent, UK
    15,236
    They use the 3G chip just as a piggy back for the GPS circuitry, so it really does work.
  1. IPad2 as a satnav
    By Paul80 in forum iPad 2 Forum
    Last Post: 11-17-2011, 08:59 AM
  2. Which Satnav on iPad
    By Talcenty in forum iPad General Discussions
    Last Post: 05-09-2011, 05:39 PM
  3. Best Buy Holding Special iPad 2 Event This Sunday
    By Maura in forum Apple iPad News
    Last Post: 04-20-2011, 02:14 PM
  4. Another satnav question
    By Quicksilver71 in forum iPad General Discussions
    Last Post: 03-23-2011, 11:45 PM
  5. Some satnav questions
    Last Post: 03-18-2011, 08:58 AM
best sat nav app for ipad 2
can an ipad be used as a sat nav
can an ipad be used as satnav
can ipad be used as sat nav
can you use ipad as sat nav
ipad 2 sat nav app
ipad sat nav app
myprepaid.telstra.com/ipad
sat nav ipad app
sat nav on ipad
streets and trips for ipad
using ipad for sat nav
