Results 1 to 5 of 5
Thread: Help!!!
    191126
    Apr 2012
    Help!!!
    hi!
    a few days ago my iPad 2 fell out of the window and the LCD and Touchscreen crushed. I would buy a new tochscreen and LCD but I don't know if everything else is working right and i don't want to spend any money on an iPad that doesn't work properly. so my question is: is there any way to check things like WiFi, Bluetooth, Camera... without using the Touchscreen? any help is appreciated!!
    thanks,
    maxwell
    33574
    25 times
    Feb 2011
    Levittown pa
    678
    Quote Originally Posted by TheMaxwell
    hi!
    thanks,
    maxwell
    If you can salvage it via DYI I think it would be a miracle.
    take it to nearest apple store and ask if it is even repairable. Price to repair will approach price to rebuy.
    191126
    Apr 2012
    well I think that I could do it. all i need is a touchscreen to check if everything is working as it should be. I can still sync it,charge it and see the lock screen.
    oh and I took it to an apple shop, well kind of an apple shop (I live in austria and we don't actually have one) and they said its unrepairable. but just because the right corner is...well a little bit smashed. but i wouldn't mind it cause i can hide that behind a silicon cover
    97693
    545 times
    Sep 2011
    Michigan. USA
    15,721
    Quote Originally Posted by TheMaxwell View Post
    hi!
    thanks,
    maxwell
    Hi maxwell--
    I am going to delete your other post as it is a duplicate. Please do not do this as it makes it hard for others to follow and provide help when they can. It is also against forum rules.
    Thanks.
    Skimonkey
    79622
    9 times
    Jul 2011
    Pelican Island, NJ
    286
    Be sure you know what you're doing. I repair iPhones and iPod's all the time and personally, I wouldn't attempt to change out an iPad screen. Good luck and please keep us posted on the outcome.
    ~~32GB iPad3~~16GB iPad1~~80GB iPod Classic~~iPhone 4~~
ipad 2 fell and now no wifi
ipad 2 fell no wifi
ipad 2 lcd not working
ipad2 lock touchscreen doesn't work
lcd of my ipad is not working properly
verizon webmail
Tags for this Thread
