No sound from ipad 2
This is a discussion on No sound from ipad 2 within the iPad 2 Forum forums, part of the Apple iPad Discussions category; The only sound I get out this thing, is if I go to Settings, and move the sound volume slide bar. Sound is not locked. ...
Results 1 to 9 of 9
    189524
    Apr 2012
    6
    The only sound I get out this thing, is if I go to Settings, and move the sound volume slide bar. Sound is not locked. It can be changed with the rocker switch. I'm sorry if this has been done earlier. I tried searching for info but got none. Please help!
    177736
    20 times
    Mar 2012
    UK
    282
    The symtoms you discribe do indeed sound like the mute slider switch, or its muted, as that's exactly the effect you get. some operation sounds work but not the main sound, but you say you have checked this.
    As you can hear some sounds this rules out there being a problem with the earphone jack. It certainly sounds like you have a setting somewhere muting it.
    Make sure bluetooth too is disabled in case somethings got screwed up there.
    I doubt it will make much difference in this instance, but when desperate, if your've not already done it. Always worth doing a none destrucive reboot, by hold down the Home and on/off buttons at the same time... you never know.. Hope you sort it out... let us know what it was.
    172732
    8 times
    Mar 2012
    333
    Or the mute is selected in the quick launch bar.Double press home,scroll to the left and check if it is not muted
    177736
    20 times
    Mar 2012
    UK
    282
    Quote Originally Posted by Semel View Post
    I forgot that one..lol and you managed it, in one line too..lmao... I do hope it does turn out to be something silly. :-) which is likely, I'm sure.
    189524
    Apr 2012
    6
    Thank You both. You gave me the solution. I do get sound from the headphones. However, no sound without. The problem I believe was from using that stupid stylus my daughter got me, that has a plastic pin that you put in the headphone jack. So, anyone have an idea of what I can do? Do I need to take it down and have a new jack installed?
    Thanks again
    189524
    Apr 2012
    6
    Well, I tried the reboot, but held it in too long. My daughter came over and properly rebooted it, and Bazinga! I now have sound back. Thanks guys for the cure for the problem. If only I wasn't so stupid I'd have had it taken care of earlier.
    189524
    Apr 2012
    6
    UPDATE!
    I have sound when playing music, or the radio app. But from none of the other apps such as games. I checked the settings in the games and they are all set with volume in the middle. ***?
    DOUBLE UPDATE!
    I got it fixed. I finally found the multi-tasking bar, and I also turned off everything to the cloud, as I don't use it.
    A Big Thanks to all who helped. I really appreciate it!
    33574
    24 times
    Feb 2011
    Levittown pa
    678
    Quote Originally Posted by tthelen
    UPDATE!
    Change the switch setting from rotation lock to mute in general settings
    Then toggle mute on and off from the physical switch.
    Then test again.
    Works on select sound problems resulting from upgrade to ios5.
    Good luck
    189524
    Apr 2012
    6
    UPDATE!
    DOUBLE UPDATE
    Thanks to all,
    I got it fixed. I believe the problem was in the Muti-task bar. I finally found that, and also, I shut off all the stuff dealing with the cloud, as I don't use it. I also changed the lock rotation to Mute. I think that's what really fixed it.
    A Big Thanks to all that helped!
  1. The only sound I get is alerts, can you tell me how to fix sound
    By melindagedwards in forum New Member Introductions - Site Assistance
    Last Post: 11-05-2012, 01:48 PM
  2. Replies: 0
    Last Post: 01-01-2012, 08:07 AM
  3. Bluetooth and Bose sound dock suddenly drops sound level
    By J_mccasland in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-06-2011, 11:16 AM
  4. Replies: 0
    Last Post: 03-01-2011, 12:19 AM
  5. How Do These Sound Boxes Make Sound?
    By padmeup in forum iPad General Discussions
    Last Post: 09-10-2010, 09:08 PM
how to get sound on ipad 2
ipad 2 no sound
ipad 2 no sound fix
ipad no volume slider
ipad2 no sound
no sound ipad 2
no sound ipad2
no sound on ipad
no sound on ipad 2
no sound on ipad2
no sounds on ipad 2
sound not working on ipad 2
