no spell check
This is a discussion on no spell check within the iPad 2 Forum forums, part of the Apple iPad Discussions category; have had an ipad 2 for a little over a month. trying to make it my main portable computer device. found that it is supposed ...
Results 1 to 5 of 5
Thread: no spell check
    177160
    Mar 2012
    tucson
    6
    no spell check
    have had an ipad 2 for a little over a month. trying to make it my main portable computer device. found that it is supposed to spell check. but it doesn't. for example several errors were not highlighted or corrected right now. i use a zagg blue tooth keyboard. any clues?
    iPad Wizard
    49745
    370 times
    6,597
    Have you turned it on:
    Settings > General > Keyboard > Check Spelling > on
    177160
    Mar 2012
    tucson
    6
    Yes, "check spelling" is on.
    177160
    Mar 2012
    tucson
    6
    have never used the ipad 2 without the external keyboard since the first week i had the ipad. if zagg keyboard off, spell check works. if using zagg keyboard, no spell check. apple tech support says no known issue*, however..... zagg says this is an issue for all bluetooth keyboards with ipad; something in bluetooth interface in ios turns off auto correct and spell check.
    *chat with apple tech support lowered opinion of expertise. after discussing symptoms, guy went away for several minutes, and than asked me to check settings. beyond that he had no info. the first thing i would ask is level of os and settings.
    177160
    Mar 2012
    tucson
    6
    verified in apple store that bluetooth keyboards do not work with spell check
  1. Spell Check - Dictionary
    By dgk in forum iPad Help
    Last Post: 10-09-2011, 02:18 AM
  2. Spell Check
    By Quinpac in forum iPad Help
    Last Post: 05-28-2011, 02:11 AM
  3. Spell check documentstogo
    By dranzo in forum iPad Apps
    Last Post: 05-25-2011, 11:22 AM
  4. Can't have spell check without autocorrect
    By dragon499 in forum iPad OS
    Last Post: 12-12-2010, 10:33 AM
edit>spelling ipad
how to correct wrong spelling on zagg keyboard
ipad spell check
ipad spell check doesn't work
safari on ipad has no spelling check
spell check doesn't work ipad
spell check for ipad
spell check on ipad
why doesn't apple spell check work on external keyboard?
why doesn't spellcheck work with ipad external keyboard
zagg keyboard and spell check
zagg keyboard spell check
