Results 1 to 7 of 7
    154282
    Jan 2012
    Devon
    13
    Am I sill connected?
    After several months of use, my ipad 2 still puzzles me. It seems strange to me, after years of computer use. that apps arejust left to run on ratherthan being turned off or shut down. It seems the suggested method is returning to the home screen, but if i've got that right and I'm using wifi. how do I know for sure that I'm no longer connected?
    Any help would be gratefully received.
    Thanks Chris P
    29345
    51 times
    Penarth, Wales, UK
    1,939
    A quick easy way to disconnect yourself from interweb is turn airplane mode on in settings
    154282
    Jan 2012
    Devon
    13
    Quote Originally Posted by sjleworthy View Post
    I might be doing something wrong but doing that for me still leaves me connected. The only thing I've found to work is turning off wifi in settings, but that's a pain.
    iPad Ninja
    62473
    63 times
    Jun 2011
    1,608
    Airplane mode disables the radio for both wifi and cellular, so you cannot still be connected unless you manually turn your wifi radio back on.
    Are you Jailbroken? Running anything that might bypass airplane mode?
    154282
    Jan 2012
    Devon
    13
    Quote Originally Posted by thewitt
    Thanks for the reply but that is still not what i'm finding. I tried making a connection while in airplane mode and got through with no problem. I then tried to enter airplane mode after I had connected to an online forum and that worked too.
    In answer to both your questions, No.
    I still had to disconnect by turning wi-fi off in Settings.
    Regards, Chris P
    iPad Ninja
    62473
    63 times
    Jun 2011
    1,608
    Quote Originally Posted by crispy51 View Post
    Regards, Chris P
    I'm sorry but your device is broken if that's the case.
    Airplane mode turns off the radios. That's what it's for. You cannot connect without the radios.
    Though you might try a full restore with the latest iOS update, it's definitely not working as its supposed to work.
    Take it to the Apple store.
    154282
    Jan 2012
    Devon
    13
    Thanks to those offering help on this one, I still can't work out what has changed, but today for the first time when I turned on airplane mode, it immediately turned wi-fi off. Before when I tried, you could see both the airplane icon and the wi-fi signal beside it.
    As it seems to be working correctly now, I'll keep my fingers crossed and close this thread.
    Regards
    Chris P
  1. Connected But Not Connected
    By spacelord in forum iPad 1 Forum
    Last Post: 12-18-2011, 08:05 AM
  2. Can the iPad be connected to a TV?
    By Natalina in forum iPad General Discussions
    Last Post: 12-12-2011, 08:07 AM
  3. Not connected to the Internet?
    By George Garrigues in forum iPad Help
    Last Post: 01-30-2011, 01:08 PM
  4. Internet not connected?
    By Mommaanddaddyward in forum iPad General Discussions
    Last Post: 12-01-2010, 01:09 AM
  5. How can I tell if my TV is internet connected?
    By SweetPoison in forum Off-Topic
    Last Post: 11-27-2010, 12:46 PM
airplane mode for ipad 2
can permissions bypass airplane mode
how to know if im connected in ipad 2
ipad 2 airplane mode
ipad2 has no email received after airplane mode?
