Is this really possible in ipad ?
This is a discussion on Is this really possible in ipad ? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I have an ipad2 unjailbroken I recently read the features of iFiles.. With iFiles, will I be able to paste word or excel files from ...
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Mickey330
Thread: Is this really possible in ipad ?
    177642
    Mar 2012
    chennai
    8
    I recently read the features of iFiles.. With iFiles, will I be able to paste word or excel files from my PC to my ipad and later view/edit them in my iPad
    Also I now have ios5.0 ... Now that 5.1 is out, is there any way I can upgrade it to 5.0.1 so that I'll be able to jailbreak my device.....
    13576
    750 times
    Aug 2010
    Western NY state (USA)
    9,312
    Quote Originally Posted by last_ride View Post
    Yes on the iFiles question (if you mean the app you buy from the App Store). The app has the capability to "broadcast" (for lack of a better word) the IP address which you can pick up with your computer's web browser, as long as you are on the same WiDi network. So, you can upload files to it. In addition, the app supports the "Open In..." function, so if the file can't be viewed in iFiles (or viewed well or edited), you can always elect to open it in another app that can read/edit the file.
    You can also map the iFiles app as a network on you computer (using the same IP address). Then, with iFiles running on the iPad, it is a simple drag 'n' drop - versus having to browse and then upload if using the web browser interface.
    Unfortunately, that's the good part of this answer. The bad part is that you cannot upgrade that iPad2 to iOS 5.0.1. Now that Apple has stopped signing that firmware version, your only option is to upgrade to 5.1 - which does not have a jailbreak ... yet. Sorry.
    177642
    Mar 2012
    chennai
    8
    Quote Originally Posted by Mickey330 View Post
    Could not understand the first part mate ... So now if I have transfered a Word file from my PC to my iPad, will I be able to view the word file offline even after turning off the Wifi connection
    13576
    750 times
    Aug 2010
    9,312
    Yes. If you have used iDiles to move that word document to your iPad, it is there. So, you can turn off WiFi and still be able to open the Word file on the iPad.
    Just know that, WiFi on or not, if you make any changes to the document on the iPad (or the computer, for that matter), the changes will not automatically sync.
    last_ride likes this.
    145653
    25 times
    Jan 2012
    341
    I believe there is some program that allows you to downgrade you iOS,I think it's something by redsn0w but I'm not sure
    13576
    750 times
    Aug 2010
    9,312
    No, nothing will allow you to downgrade an iPad2 to iOS 5.0.1 once you are on iOS 5.1.
best hdmi
can a ipad 2 be unjailbroken
can't upload files with ifiles app for ipad
chennai
editing word document off line on ipad
ifiles
ifiles cannot open in
ifiles ipadforums
ipad word documents offline
off line ipad word documents
unjailbroken ipad2 file viewer
using partmate with ipad
