i need some help
This is a discussion on i need some help within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hello people, i have the ipad 2 jailbroken running ios 5. well, i kinda need it for work so i have to run some things ...
Results 1 to 1 of 1
    180826
    Mar 2012
    Lima
    i need some help
    Hello people, i have the ipad 2 jailbroken running ios 5. well, i kinda need it for work so i have to run some things and use a USB flash drive. but i need flash. a friend told me to use Frash, but i heard it's not working anymore. then , i watched several videos of dudes usimg their flash drives with iFile, but mine is not working at all, and i tried with 4 more, without luck. i was searching on the web and i found that this trick works only with 4.3.3 jailbreak.
    Can you guys tell me if this is true, about the flash drive and Frash?
    thank you in advance, and sorry for bad english
frash ipad 2
frash ipad not working
frash not working on ipad 2
how to use frash ipad 2
judith abendschein
use flash drive on ios 5 jailbroken ipad
using flash disk on ipad 2 jailbroken
using flash drive with non jailbroken ipad
